solidsnake204
- Mar 19, 2010
I have a Samsung SH-S223 SATA DVD-RW drive.
However, as a little sort of project, I would like to change the green LED for a blue LED (To match the case) and also very slightly enlarge the hole for the LED light (Just using a drill to do this, easy enough).
I understand how to do it (At least I think I do...): Unsolder the LED, remove it from the plastic holder, insert new LED into holder, solder LED, done.
I myself wont be doing the soldering (For a start I don't even own a soldering iron), so I'll let my friend do the soldering part.
But my questions are about the LED itself. I measured the width across the LED and it was 5mm. However, 5mm LED's come in 5v and 12v varieties, would it be safe to assume that the drive LED would be a 5v?
As for the LED, would this LED work? (And which one should I get, diffused or clear?)
http://maplin.co.uk/Module.aspx?ModuleNo=12703
Thanks in advance.
Thanks in advance.
