Hard mousepad similar to Ratpadz?
Discussion in 'Mice and Keyboards' started by Scheibler1, Dec 9, 2016.
  1. Scheibler1
    Scheibler1 [H]ard|Gawd
    1,372
    Jul 8, 2005
    Anyone know of a mousepad that is similar to the ratpadz xt? Should have never got rid of mine!
  2. rbarr110
    rbarr110 Limp Gawd
    263
    Jan 8, 2003
    Good question, my 2 Ratpadz are very worn out and overdue for replacement.
  3. entropism
    entropism 2[H]4U
    3,203
    Dec 23, 2004
    OK, so I was GOING to recommend Razer's eXactMat (seriously, fuck them for the capitalization) but when I went looking for a link, it seems it's been discontinued. They have others (The Manticore, Invicta, possibly the firefly) that have the same aluminum and bonded material design, but they seem a bit on the expensive side for me. All I know is that I've had my Exactmat (no seriously, fuck whoever came up with that capitalization) for about 10 years now, and it's still going strong.
    I noticed Best Buy sells this: http://www.bestbuy.com/site/razer-v...g-mouse-pad-dark-gray/1199663.p?skuId=1199663 I own it, and I don't like it nearly as much as my exactmat. The plastic is just too lightweight for me.
    If you want cheaper, I'm pretty sure you won't wear through this one: https://www.amazon.com/Satechi-Aluminum-Non-slip-Rubber-Silver/dp/B01I496BX8?th=1
  4. DWolvin
    DWolvin [H]ard|Gawd
    1,607
    Nov 13, 2002
    I picked up a Feenix Dimora recently, I'd say it's pretty similar except thinner and larger surface
  5. Deadjasper
    Deadjasper [H]ard|Gawd
    1,332
    Oct 28, 2001
    I've had my 3m Precise Mousing Surface for like forever. It's well worn but still functions perfectly. Wish they still made this particular model. It has a built in gel wrist pad.
  6. broddy
    broddy Limp Gawd
    192
    Oct 18, 2011
    Yep, I'm using it too. My company uses them and they work so well. Then I bought it for personal use too.
  7. DWolvin
    DWolvin [H]ard|Gawd
    1,607
    Nov 13, 2002
    They are pretty great- Is your old one the gray and black hex pattern?
  8. Deadjasper
    1,332
    Oct 28, 2001
    Mine is solid black. It's old old old.
