I often just run dban then run a small bead of solder with my high power soldering iron across the motor terminals. Anyone dumb enough to put that into their machine is in for a rude surprise.
Thermite = Win!
I need to try this some day. Need to find a way to grind up some pop cans without mess. For the rust I can probably find some scrap pieces of metal and use electrolysis in salt water then scrape it off.
They actually record the whole process for you from pickup to shredding if you opt for the "documentation" option - if I was so inclined to watch a 98 minute movie about it.Ouch $1200? I'm in the wrong line of business. Actually I wonder what it takes to become certified to do this professionally. With a well build device it would make a nice side job. It's not like its something that happens often. Probably why it's so expensive. That and potential liability issues.
The use industrial shredders like the this - http://www.youtube.com/watch?v=sQYPCPB1g3o
It's not degaussing, it's physical destruction to less than half-inch pieces, then proper disposal (because they contain lead, etc). Technically, just dumping a single hard drive in our standard garbage dumpster could cost us $10,000 in fines.
Those are always fun to watch. And yeah disposal probably cost's some money too so that's probably included in the price. Guess from a company's point of view it's not really a lot of money at all to spend.
Cheapest, maybe. Consider; if the data on the drives is covered by something like PCI or DOJ, you need to be able to prove that the drive was destroyed in a manner that renders the data unrecoverable. And saying "I took a sledge hammer to it" is not acceptable.Physically destroying the HDDs yourself and probably discarding pieces of it at different locations is probably the best/cheapest way. Unless of course some other party is willing to spend a good amount of money recovering said data if physically recovered then in that case thermite is the only option to be sure.
