videobruce
- Jan 21, 2005
I wasn't sure where to put this.
The MB (Foxconn N570SM2AA0) already has a serial port built in. I was having issues with the XP driver (nothing else available), so I purchased a PCIe serial port card and installed it. I did disable the on board port first.
I have two bootable drives and this happens with the orginal drive and the 2nd drive that I reloaded the O/S after I added the card. The O/S hangs 45 seconds, then continues to boot. I'm sure it's this serial card. Again this is with or w/o the driver installed running XP Pro w/sp2
The other possible related issue is com ports 1 & 2 are not available with the on board port disabled. Where in the registry can I regain these port numbers?
Hope this made sense.
