madFive
metal[H]ead
- Mar 26, 2008
Ok, really dumb question for Note 3 users. Google is failing me on this.
How do I change the duration/length of the haptic feedback vibration? This is the vibration you feel when you hit the back button or menu button at the bottom. It’s also used for a few keys in the keyboard and probably more stuff I haven’t noticed yet.
Backstory: I dropped my old Note3 last week and cracked the screen, had insurance, got new Note3, now I’m setting up the new one and getting all my settings back to how I like them. (I still have the old one currently for comparison)
On my old phone, hitting the back button etc, the haptic feedback is a nice pleasant short click feeling. On the new phone the haptic vibration is a long dull numbing reverberating pulse that is driving me nuts!!
I found the settings to turn the haptic feedback off/on and to adjust the volume/intensity of the vibration, but those aren’t the settings I’m looking for. Somewhere in there is a setting to adjust the LENGTH/DURATION/TYPE of the vibration, so you can have it a short click feeling (like typing on the on-screen keyboard) or the long pulse it’s using now.
So how do I adjust that? Is there still a way to adjust, or was that removed by an update at some point? My old phone still has it correct, but maybe I set it a while ago, then the option was removed so it’s just permanently that way?
BTW, these are both a stock Note3’s, 4.4.2. I’m not planning to root or mod the phone to fix this; just hoping to find the regular option in the stock settings. Yes, I know you all hate touch-wiz; don't start ranting about that now - just help me fix my button vibration!
