Jan 13, 2014 #1 B bds1904 Gawd Joined Aug 10, 2011 Messages 1,007 What do you guys reccomend for a Half-Height PCIe 8x w/ SFF-8087 JBOD HBA? Going to go in a c6100 node that is going to be used for a ZFS server. 3Gb/sec would be okay, but 6Gb/sec would be better.
Jan 14, 2014 #2 B brutalizer [H]ard|Gawd Joined Oct 23, 2010 Messages 1,602 Why not the IBM M1015 with a bracket that turns SFF8087 into a SFF8088?
Jan 14, 2014 #3 N nry Limp Gawd Joined Jul 10, 2008 Messages 409 M1015 is a cheap solution as you can flash to IT mode. Im sure the C6100 takes the Dell Y8Y69 too, don't know too much about that though. Will the drives be in the C6100?
Jan 14, 2014 #4 B bds1904 Gawd Joined Aug 10, 2011 Messages 1,007 Well, changing the plan a little bit. Going to go with an external SAS enclosure w/ sff-8088. Anyone have anything to say about the LSI SAS3801E when used with omnios + nappit?
Jan 14, 2014 #5 P patrickdk Gawd Joined Jan 3, 2012 Messages 744 the lsi 3g sas cards are not normally recommended, due to the closed source binary.
Jan 14, 2014 #6 B bds1904 Gawd Joined Aug 10, 2011 Messages 1,007 patrickdk said: the lsi 3g sas cards are not normally recommended, due to the closed source binary. Click to expand... what do you recommend that will fit in a half-height slot? That's the only name-brand one I have come across.
Jan 15, 2014 #7 S Stanza33 Gawd Joined Mar 31, 2010 Messages 538 Hp sc44ge cards can be had half height 3442r clone .
