HAF X + 2600K + Triple GTX 580 Water Cooled
Discussion in 'Cases & Case Modding' started by WozniakMac, Apr 22, 2011.
  1. WozniakMac
    WozniakMac [H]ard|Gawd
    1,449
    Sep 3, 2005
    I have just finished my latest build, and I can now post a picture of the final result. Comments and criticism welcome. Components listed below.
    Components:
    1. Intel i7 2600K @ 5.0GHz w/ EK Full Nickel WaterBlock
    2. Maximus IV Extreme B3
    3. 3 x eVGA GTX 580 Black Ops w/ EK GTX 580+ WaterBlocks
    4. 16GB (4x4GB) G Skill 1600MHz DDR3
    5. Swiftech MCP355 Pump with EK Rev 2 Top and Phobya Pump Mount
    6. I and H 225mL Resorvoir
    7. XSPC RX360 Radiator
    8. 3 x 200mm Cooler Master MegaFlow Fans and 4 x Akasa Apache Fans (Dead Silent!)
    9. AX1200 PSU, custom sleeved in Red, black, and white.
    10. 2 x 240GB OCZ Vertex 2 SSDs in RAID 0
    11. Plextor DVD+-RW Drive
    Thank you for looking again!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Temps!
    Load (10 Minutes):
    [​IMG]
    Idle:
    [​IMG]
  2. mannyman
    mannyman 2[H]4U
    2,854
    Jan 12, 2011
    No criticisms here. Very nice.
  3. JWD1989
    JWD1989 [H]Lite
    77
    Jul 24, 2010
    More pictures!!! Looks very very clean! Great job :)
  4. WozniakMac
    1,449
    Sep 3, 2005
    Will post more pictures and temps tomorrow. It's been a month long process, and I wanna play with it now. lol.
  5. chuckd007
    chuckd007 [H]ard|Gawd
    1,087
    Dec 8, 2007
  6. TTsar562
    TTsar562 n00b
    60
    Dec 28, 2010
    That's NICE!!!!!!
  7. DoubleTap
    DoubleTap [H]ard|Gawd
    2,028
    Dec 16, 2010
    It looks incredible, but I am surprised a 360 radiator can handle all of that.
  8. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    Very very nice, great case aswell.
  9. celwin
    celwin Gawd
    985
    Oct 18, 2006
    Same here. I wonder what are his load temps.
  10. WozniakMac
    1,449
    Sep 3, 2005
    My idle temps are low 30s and while I'm gaming I get around 45 on everything. When I run Prime 95 for 1 hour, my cpu temp jumps to around 60-65 across all cores. Pretty good considering all that I am cooling.
  11. Gorilla
    Gorilla [H]ardness Supreme
    5,913
    Sep 14, 2007
    Yeah, I wouldn't have thought that a single 360 would be enough, but I guess that as long as you are just gaming it's fine. Try running Intel Burn Test instead of p95 and run Furmark at the same time. I'd love to see what your temps would look like then.
  12. JWD1989
    JWD1989 [H]Lite
    77
    Jul 24, 2010
    I know the feeling, I've been working on a new rig for almost a month now and it is killing me! Kudos on the sleeeving job, looks super professional.
    Also, what type of rad setup are you using (push/pull)? Can't tell from the picture but that's what it looks like. Those are pretty good temps considering its a cpu+ tri gpu loop.
  13. mannyman
    mannyman 2[H]4U
    2,854
    Jan 12, 2011
    It is a very thick rad, I would assume he is using push pull.
  14. xpman
    xpman n00b
    26
    Jan 5, 2005
    Not only green, but super green. I am jealous. Great job.
  15. WozniakMac
    1,449
    Sep 3, 2005
    I am using push pull. I have 3 akasa apaches pushing and 2 x 200mm Cooler master MegaFlows Pulling. What's the point in running Furmark and IBT at the same time? If I never stress my system that much EVER, then why would I worry about that? Just saying.
  16. Adderol
    Adderol n00b
    16
    Mar 11, 2011
    +1
    good job man!
    now if you would only make to a lan party once in a while :D
  17. vjcsmoke
    vjcsmoke [H]ardness Supreme
    4,511
    Dec 5, 2006
    Great setup. I'm surprised that a single 360 rad could handle all that heat though. Have you tried those puppised on Furmark or does Nvidia throttle the power when it detects furmark now? (I think they did something about it). ^_^
  18. WozniakMac
    1,449
    Sep 3, 2005
    I have tried furmark, but only 1 card got hot. GPU1 was around 45-50 after 10 minutes of furmark. My main goal was not to see how cool I could get things, but rather how quiet. Temps are a plus for me being that the RX360 is such a good radiator that it is all I need. The matte black finish sucks bad though. It chips so easily. My whole system runs at less than 20db total. I am very happy for once, and hopefully nothing breaks. :)
  19. WozniakMac
    1,449
    Sep 3, 2005
    More pictures added.
  20. kadozer
    kadozer [H]ard|Gawd
    1,881
    Jun 29, 2007
    What is the EK thingy that spans across the 3 cards? I didn't even know they made parts like that.
  21. WozniakMac
    1,449
    Sep 3, 2005
    That connects the 3 cards in serial so that I don't have to run tubes and fittings in all the cards.
  22. Rossi~
    Rossi~ 2[H]4U
    3,479
    Dec 8, 2008
    Nice! Not a fan of the HAF but still, nice build!
    Also:
    Eh?
  23. WozniakMac
    1,449
    Sep 3, 2005
    Yes, 4x4GB.
  24. Slaughterhouse59
    Slaughterhouse59 Limp Gawd
    203
    Apr 13, 2011
    That water cooler made me a drooler...sorry for the horrible rhyme lol. That's damn nice though.
  25. vsboxerboy
    vsboxerboy 2[H]4U
    3,662
    Oct 17, 2005
    My only criticism is that there are not nearly enough pictures. How dare you tease the forum with that you arse.
  26. WozniakMac
    1,449
    Sep 3, 2005
    I will provide more pictures once I get my camera back from Canon. My 5DMarkII has a big spot on the sensor and my 50mm 1.2L won't behave on anything other than the Full Frame.
  27. misfitmatt87
    misfitmatt87 n00b
    19
    Jan 11, 2008
  28. bigddybn
    bigddybn [H]ardness Supreme
    6,898
    Nov 21, 2006
    Yeah but can it play crys......
    I guess it can.
  29. Silverghost
    Silverghost 2[H]4U
    2,627
    Dec 22, 2002
  30. rayman2k2
    rayman2k2 [H]ardness Supreme
    8,070
    Aug 6, 2002
    Any reason you picked serial instead of parallel? I plan on getting one of those this summer, and was wondering which one to get, hence why I ask.
    4x2 = 8 ಠ_ಠ
  31. vsboxerboy
    vsboxerboy 2[H]4U
    3,662
    Oct 17, 2005
    Nice lens too! Sucks to hear about the camera though, my one experience with Canon was pretty spot on though, they rush shipped it and everything.
  32. xDezor
    xDezor Limp Gawd
    441
    Sep 19, 2010
    I would also like to know. I plan on running them in parallel.
    Perhaps he doesn't trust the physics behind it?
  33. aerial-
    aerial- Limp Gawd
    192
    Mar 13, 2011
    Btw what is the speed (RPM) of you fans? You say it is silent, but something is telling me they don't run at minimum.
  34. fasteddy
    fasteddy Limp Gawd
    180
    Jan 11, 2007
    Looks great! :)
    I bet it performs great too, nice work.
  35. mls1995
    mls1995 2[H]4U
    3,275
    Jan 20, 2007
    Sweet! I wish I could build something like that, but I can tell this would be completely out of my league.
  36. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,466
    Oct 5, 2004
    Beautiful work.
    Love that you took your time and got it perfect.
    Very powerful specs.
    I'm counting up a figure of just under $4k.
  37. WozniakMac
    1,449
    Sep 3, 2005
    Silver, and others...
    Whoops on the 4x2GB Error. It's 4x4GB is what I meant.
    Aerial...
    The Akasa Apaches are running around 1200-1300rpm and they definitely are silent and at full speed. My system idles in the low to mid 30s, and never goes above 50 on anything when gaming. Not sure why no one believes me that it is all being cooled with a single RX360 while being silent too. My ambient temperature is around 68-70F in my house. Maybe that is why. We keep it fairly cool.
    SixFootDuo...
    I went through just adding everything up retail prices, and came up with around 5200 new, but I did not pay retail. I have had my Vertex 2's since they came out, I bought the board, CPU, and RAM from a local computer store my buddy owns for a good price, I already had the case, Bought 2 of the GTX 580 Black ops with my American Express Points + 123 bucks, and got a good deal on all the watercooling stuff from Sidewinder Computers. They really are the best water parts store on the net. They are very nice, and actually answer the phone when you call.
    You are probably close though, around the $4,000.00 mark.
    Everyone...
    Thanks for all the nice comments, and I really am finally happy with a computer build after years, I don't want to touch the damn thing to upgrade it. It just works as it should.
  38. WozniakMac
    1,449
    Sep 3, 2005
    Temps!
    Load (10 Minutes):
    [​IMG]
    Idle:
    [​IMG]
  39. zerounleashednl
    zerounleashednl n00b
    31
    Dec 20, 2010
    Very very nice. I've got almost the exact system and I'm also thinking about adding those water cooling components.
    A question:
    How did you do this? (the custom sleeve I mean)
  40. covertash
    covertash Gawd
    988
    Apr 24, 2006
    Beautiful work. Any chance of delving into Surround? You certainly have the horsepower to drive it. ;)
    I'm also curious about the sleeve work too. Where did you get your sleeving from? MDPC-X?
