[H] Thermal Compound TIM Round-up Candidates
Discussion in 'Overclocking & Cooling' started by FrgMstr, Jan 11, 2017.
  1. bigdogchris
    bigdogchris [H]ard as it Gets
    17,891
    Feb 19, 2008
    Not sure if this would be outside the scope of the project, but what about including comments about the viscosity of each paste? I understand the thinner products may be easier to work with but may not give as good of results as the 'thicker' stuff.
  2. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,338
    May 18, 1997
    I will try my best to notes on that and convey my thoughts.
    Peter2k likes this.
  3. capt_cope
    capt_cope Gawd
    917
    Apr 12, 2009
    Nothing like some aloe and fragrance (and god knows what else) to ensure a good clean surface...
    I think I'll stick with my favorite multi-function solvent - Everclear.
    Willypants, Kwaz, Peter2k and 2 others like this.
  4. pendragon1
    pendragon1 [H]ardForum Junkie
    13,908
    Oct 7, 2000
    you are re-cleaning after with iso right?! cause everything said before is very true...
    Peter2k likes this.
  5. thesmokingman
    thesmokingman [H]ardness Supreme
    4,925
    Nov 22, 2008
    Yea, I sterilize the surfaces before applying CLU with some isopropyl. But the actual cleaning is easier with a baby wipe than a towel and cleaner. The abundant moisture in the wipe does something to the CLU and it absorbs right into the wipe reducing the chances of contact transfer.
    Peter2k likes this.
  6. gigatexal
    gigatexal [H]ardness Supreme
    7,249
    Jun 22, 2004
    Delid and thermal paste shootout? Hella yes.
  7. Burticus
    Burticus 2[H]4U
    4,021
    Nov 7, 2005
    Cisco sends this stuff with replacement UCS blade motherboards, in syringes. I don't see a model # on the syringe anywhere, just the logo and website. When we swap the mobos we have to transplant the Xeons over to the new motherboard and re-do the grease.
    https://www.microsi.com/thermal-grease/
    It's grey and average consistency. They also ship us tons of Arctic Silver Arctic Clean fluid... but nothing to wipe it off with. I have to run to the men's room at the datacenter to get paper towels, heh.
    I personally use NHT, MX, and the Cooler Master (mini syringes that come with their heatsinks) grey greases and it's about the same as those consistency wise. I've tried the Arctic Silver stuff but it was such a pain to clean up I stopped using it. Also, not cheap.
    I could send Kyle a handful of the syringes but he appears to be looking for commercially available solutions. But as long as this stuff doesn't dry up, I should be set for thermal grease for life, LOL
    edit - oh I found it on Amazon.
    https://www.amazon.com/X23-7783D-Manufacturer-Shin-Etsu-MicroSi-Performance/dp/B01HMZBD2Y
  8. FrgMstr
    48,338
    May 18, 1997
    Already on the list. :) What is sold publicly anyway. Has been a go-to for a number of years as well.
  9. rgMekanic
    rgMekanic [H]ard|News Staff Member
    3,938
    May 13, 2013
    Wouldn't mind seeing a Xigmatek product or 2 in the list. http://www.xigmatek.com/product_list.php?categoryid=5&subcategoryid=15
    I've been using G-4512 for a couple years with good results so far, and the price is nice.
    I know you aren't testing any other products, but Arcticlean really is fucking awesome lol. I always used alcohol till on a whim I decided to try it.
  10. thesmokingman
    4,925
    Nov 22, 2008
    The list is getting huge man, it's gonna take you a month to get thru it.
  11. FrgMstr
    48,338
    May 18, 1997
    Yeah, I am done on bringing anything else in.
    This retail CPU looks like it will be good for testing. 4.9GHz at 1.35v under full load it getting toasty, which is of course where we would like to start.
  12. thesmokingman
    4,925
    Nov 22, 2008
    Oh shit, that is spicy hot! That said, temp variation between cores is great. Good job mounting.
  13. FrgMstr
    48,338
    May 18, 1997
    I am probably just going to track package temps for "scoring" in this and maybe just note per core temps.
  14. FrgMstr
    48,338
    May 18, 1997
    Still impressed with just how flat the Kaby Lake IHS are. The block was removed left to right in the picture below. This was with MG Chemicals Silicone White TIM.
    Peter2k likes this.
  15. FrgMstr
    48,338
    May 18, 1997
    Here is a look at the temp data I have been working on today and Package Temp is looking to be a very solid data point to work with after the cooling system loads.
    And I guess I should explain a bit of what you are looking at.
    The heavy RED line is the package temperature. The other green lines you see around it are per core temperatures. I have not seen the reported "Recent average" package temp change since the cooling system loaded up, which was pretty quick given I did not give it much time to cool.
    Ripskin and thesmokingman like this.
  16. FrgMstr
    48,338
    May 18, 1997
    The Noctua NH-T1 looked damn good on the mating surface as well. The picture does not do it justice at all. I tried a few different angles, but the reflection makes it look a lot thicker than it was.
  17. Nanogrip
    Nanogrip Limp Gawd
    440
    Dec 4, 2016
    Wouldn't cleaning be much easier with acetone? If plastics are a concern, then WD-40, then followed up by a dab of acetone on a shop paper towel, nickles and pennies.
    I've used only AS5 and Jetart Nano Diamond (Jetart also has carbon nanotube compound, never tried it though) , and cheap silicon Y-500 for everything not mine, so will be looking into this one.
  18. FrgMstr
    48,338
    May 18, 1997
    Y'all are really worried a bit too much on this front. 99% iso cleans up just fine and does an excellent job.
    Ripskin and Nanogrip like this.
  19. capt_cope
    capt_cope Gawd
    917
    Apr 12, 2009
    The problem with acetone is that most of the stuff you can buy is likely to have a bunch of impurities (unless you've got access to ACS / reagent grade chemicals but even so the cost...) that are left behind when it evaporates. Pour a little in a small dish, it should evaporate pretty quickly and it will probably leave a greasy film. It's why I like everclear, it's not exactly scientific grade, but it's a hell of a lot cheaper (and has way fewer impurities than any acetone I've ever touched in either the beauty or paint sections.)
    Ethanol and a coffee filter work like a champ for as5...
  20. Peter2k
    Peter2k Limp Gawd
    309
    Apr 25, 2016
    AS5 is nothing :ROFLMAO:
    and it's also not conducting at least
    the liquid metal I used, both from coollaboratory and Phobya, not only handle like :banghead:
    they also want to go inside paper towels or anything else I tried like :banghead:
    like I tried to get a drop of oil into a wet paper towel
    gonna give the baby wipes a try
    they do have some kind of structure to them and handle nice themselves
    I don't think it's about the stuff inside them at all
    and of course gonna clean it better of after them
  21. Singularity_Survivor
    Singularity_Survivor Limp Gawd
    212
    Apr 7, 2016
    The nerdism humor is strong with this thread.
    Nanogrip, FrgMstr and Peter2k like this.
  22. Nenu
    Nenu [H]ardened
    18,885
    Apr 28, 2007
    Not for DC but definitely does with AC.
  23. FrgMstr
    48,338
    May 18, 1997
    Yes, well, when you rely on the equipment to be there tomorrow, I guess maybe we treat it better than you do. That said, we hardly use kid gloves. Please share how you are killing new processors. I am very interested in the specifics.
  24. michalrz
    michalrz 2[H]4U
    2,730
    Jun 4, 2012
    Last and only thermal death of a CPU for me was a Barton core IIRC. Friend forgot to put the rad on.
    I ran a K8 without a heatsink (after delidding the surfaces had a gap between them), it shutdown after 3-4 seconds, twice.
    I often see Core 2 Duos running for years without heatsinks because of badly installed/failed push-pins. It just throttles.
    Now, voltage will get you a slow degradation that's easily confused for PSU or mobo failure.
  25. Nanogrip
    Nanogrip Limp Gawd
    440
    Dec 4, 2016
    Yeah acetone does leave a slight residue. It's a hell of a remover though, from white-out to gum. I use only the ones in the paint section.
    Coffee filter! Okay, you gave me an idea for cleanups, they don't have lint and are pretty clean to begin with.
  26. bal3wolf
    bal3wolf Limp Gawd
    264
    May 14, 2008
    when i redid some of my loop and switched cases i got Thermal Grizzly Kryonaut seems to work pretty good somewhat a pain to spread out tho looking foward to results from all pastes.
  27. bal3wolf
    bal3wolf Limp Gawd
    264
    May 14, 2008
    That annoys me also not just with motherboards i have a grid+ and it wont let me go below 40%.
  28. FrgMstr
    48,338
    May 18, 1997
    Liability and support....
  29. FearTheCow
    FearTheCow [H]ardness Supreme
    4,731
    May 2, 2006
    Reading this thread made me realize what a bunch of sissies you all are with cleaning thermal paste off, I use gasoline and wipe the chip on my ass, gets it perfectly clean Everytime!
    Ultima99 and thesmokingman like this.
  30. Eldata
    Eldata Limp Gawd
    366
    May 10, 2011
    Should we call that half-assed perfection?
  31. PliotronX
    PliotronX 2[H]4U
    2,066
    Aug 8, 2000
    Crazy how MX-2 and AS5 hold up! I do have a very un-[H]ard request but its for practical reasons.. This Chinese "Bangood" silicone grease that's like a dollar shipped for 30g is what I use at work because my coworkers have a habit of kyping and using my good grease. I'm just curious how much worse it performs because I have not seen any professional comparisons with it (for obvious reasons though). No big deal though, some things are better left unknown.
  32. IKV1476
    IKV1476 Lurker
    282
    Dec 26, 2005
    Very late to this but I was just thinking how would engine oil work as a TIM?
    It would be interesting I think, since it seems some/many/most TIMs are a grease type material anyways.
  33. Nenu
    Nenu [H]ardened
    18,885
    Apr 28, 2007
    That would be quite an invisible mess in the making.
    It shouldnt stop connections being made if it does spread or get transferred around but the additives in it might conduct enough to prevent electronics working, or cause damage.
  34. pendragon1
    13,908
    Oct 7, 2000
    lol DO NOT google "day stretcher", its not gonna give you the results youre expecting!
    Jim Kim, Ripskin and Nanogrip like this.
  35. WhoBeDaPlaya
    WhoBeDaPlaya 2[H]4U
    2,485
    Dec 16, 2002
    Just like that one time I Googled "shortstroking" and got a how-to on how to have sex with my car :eek:
    pendragon1 likes this.
  36. Junkboy
    Junkboy [H]Lite
    107
    Apr 27, 2012
    Eagerly awaiting differences if any on mx4, NHT1, and Kryonaut which have been my go to pastes for the last half decade. Thermal Grizzly has been really good so far as the most recent one to pop up.
  37. mnewxcv
    mnewxcv [H]ardness Supreme
    6,470
    Mar 4, 2007
    I had to order TIM a few weeks back and couldn't wait any longer for results. I went with NHT1 because its so damn easy to apply. And its pretty cheap. If it tests within 5c of the top 5 TIMs I wont get anything else ever. Gelid GC was ok but I didn't notice a temp difference and it was harder to apply. IC diamond worked well, but what a bitch to apply and IMO overpriced.
  38. BitMaster
    BitMaster Limp Gawd
    367
    Nov 10, 2016
    Do you remember the bad odor of a burned AMD Athlon 1200 on that "organic" substrate the die was on ?
    I killed my friends brand new AMD back then cuz the heatsink wasnt seated properly, the moment I switched brand new rig on the damn chip went up in smoke which itself got sucked in by the PSU fan and blown out at the back, dark-grey stinky smoke, it really looked like a steam powered Locomotive.
    I have burned a few, sadly, over time, but none was THAT spectacular.
    It also happened in my living room, the room stank for three days. It was a real pain to get that smell out but worth the laugh....all got replaced as the plastic cpu socket had a failure and thus the disaster. Still, all the work involved remains your own part, replaced parts aside.
    The 2nd I killed was due to long time overclocking. It suddenly quit and wouldnt boot at all in any board, 2600k that was.
    My 3rd kill came shortly after, while looking for a new setup to replace that 2600k at 4.8-5G. I bricked 3 boards and killed 1 6700k :)
    What a fucking pain all those RMA's were, custom waterloop with GPU and VRMs...felt like a hardware reviewer testing boards..waahaaaaa
    I never found out what killed the 6700k....it clipped out and went dead at 4700MHz full load test...BLING--->DEAD
    Intel replaced it with no questions asked I have to admit, as well as all 3 boards got replaced without any issue but I got no feedback on what broke the CPU.
    In my RMA I clearly stated it went dead while stress testing an 4.7 OC setting ( Asus tool , quick and dirty method to see where the journey goes to...it went SOUTH )
    Still, it's not that easy to kill one. I have run my CPU's with the heavy copper waterblock alone to boot the system and enter bios etc.. no worries.
    I can run the system without any fan at all, stop the pump and go online for a while until it would heat up, throttle down and save itself.
    Peter2k and FrgMstr like this.
  39. Starbomba
    Starbomba Limp Gawd
    254
    Aug 24, 2014
    After all this time, i continue using MX-4 as my go-to TIM. Good enough and cheap, an unbeatable combination.
  40. rgMekanic
    3,938
    May 13, 2013
    Just picked up a tube of Hydronaut for my new build, couldn't justify the price jump for Kryonaut.
    Damn impressive stuff performance wise, but a bitch to apply. Even after soaking the tube in hot water for a few minutes, it has a consistency just under bubblegum.
