[H] Thermal Compound TIM Round-up Candidates
Discussion in 'Overclocking & Cooling' started by Kyle_Bennett, Jan 11, 2017.
  1. Kyle_Bennett
    Kyle_Bennett HardForum Admin Staff Member
    48,957
    May 18, 1997
    OK, getting geared up for a TIM Round-up. Hopefully next week I will get around to de-lidding our 7700K retail CPU that I bought. I figured since we were going to be doing some delidding testing, I might as well spend some time and do a TIM roundup after I get the delidding done.
    Here is my list of candidates that I have already purchased and are on the way. I am NOT going to get into all the liquid metal TIMs for usage between the IHS and water block.
    Let me know if I have missed any products that you think should be included.
    ARCTIC MX-4 Thermal Compound Paste, Carbon Based High Performance, Heatsink Paste, Thermal Compound CPU for All Coolers, Thermal Interface Material - 4 Grams
    Arctic Silver Arctic Alumina 1.75g Premium Ceramic Polysynthetic Thermal Cooling Compound (AA-1.75G)
    Artic Silver AS5-12G Silver Thermal Compound 12 g Syringe
    Coollaboratory Liquid Copper
    Gelid Solutions GC-Extreme Thermal Compound TC-GC-03-A
    IC Diamond 24 Carat 4.8 Gram Thermal Compound
    Innovation Cooling Diamond "7 Carat" Thermal Compound - 1.5 Grams
    Noctua NT-H1 Thermal Compound
    Phobya HeGrease Extreme 1g
    Prolimatech Pk-1 Nano Aluminum Thermal Compound - 5g
    Prolimatech PK-3 Nano Aluminium Thermal Compound 1.5g
    Thermal Grizzly Kryonaut Thermal Grease Paste - 1.0 Gram
    Tuniq TX-2 High Performance Thermal Compound Paste Grease
    Tuniq TX-4 1ml Heat Conducting Thermal Compound Paste Grease
    Added: X23-7783D, Direct From Manufacturer Shin-Etsu
  2. Killerxp100
    Killerxp100 Gawd
    743
    May 20, 2011
    Looks solid looking forward to the results.
    gigatexal likes this.
  3. Araxie
    Araxie [H]ardness Supreme
    6,351
    Feb 11, 2013
    Kayle please, can you add some Shin Etsu stuff to the mix?. Shin Etsu have probably one of the best non-conductive, non-metal TIM out there, it's the one used by EVGA and Corsair as pre-applied TIM on all the AIOs, it's one of the main reason why people once change/remount a Corsair AIO never get the same result as with the OEM TIM.
    The Shin Etsu X23-7783D would be a great choice, Zero Cure time, easy to spread, easy to clean..
  4. Chapeau
    Chapeau Gawd
    740
    Jul 17, 2016
    EK (Enerdyne) Indigo XS
    Phase change metal alloy.
    So unknown compared to traditional TIM's. Also easier to get a result that with the liquid metal alternatives so warrants a look?
    TrailRunner likes this.
  5. Kyle_Bennett
    48,957
    May 18, 1997
    Added.
  6. Kyle_Bennett
    48,957
    May 18, 1997
    Not dealing with those one time application things for $20 or $30.
  7. Chapeau
    Chapeau Gawd
    740
    Jul 17, 2016
    Yeah - price is NOT great. However, it's not as terrible because you do get two in the pack.
    :cool: So... only half as terrible.
  8. Kyle_Bennett
    48,957
    May 18, 1997
    But when I might mount a block 3 to 6 times during testing, I am not dropping $60 on that. And quite frankly, I just think they are sort of bullshit for newbies. So man-up and don't make me come over there and take your [H]Card. ;)
  9. MrGuvernment
    MrGuvernment [H]ard as it Gets
    19,162
    Aug 3, 2004
  10. Krenum
    Krenum [H]ardForum Junkie
    15,263
    Apr 29, 2005
    Looks like a great list. Using the Noctua myself, but I a very partial to IC Diamond when I have it around.
  11. Kyle_Bennett
    48,957
    May 18, 1997
    Pervert.
    alxlwson and JDiesel like this.
  12. Brackle
    Brackle Old Timer
    7,257
    Jun 19, 2003
    Cheese. We need to see if it is better at cooling after all these years!
  13. Kyle_Bennett
    48,957
    May 18, 1997
    I thought we already settled that. ;)
  14. Brackle
    Brackle Old Timer
    7,257
    Jun 19, 2003
    Laugh it was worth a shot!
  15. Kyle_Bennett
    48,957
    May 18, 1997
    To catch the newbies up....
    http://www.hardocp.com/article/2009/04/07/thermal_paste_shootout_q209
    American cheese is the name given to cheese that goes through a specific type of pasteurization process. Often yellow or orange in color, this cheese has also been known to take on a white color. A versatile type of cheese, tracing its origins back to the very start of this great nation, American cheese has found uses in barbeques and kitchens all over the country. Finding detailed specs has been no easy feat so without measurements in specific gravity or thermal conductivity we will be testing purely on its performance.
    We do however suggest you stay away from cheese if you are overclocking. ;)
    tungt88, Mav451, Ultima99 and 2 others like this.
  16. Peter2k
    Peter2k Limp Gawd
    340
    Apr 25, 2016
    Just so you know
    some of the stuff is a pain to remove
    especially if you're swapping and testing a lot
    [​IMG]
    [​IMG]
    that being said I'm especially interested how the liquid ones handle
    those would be
    liquid ultra
    Grizzly conductonaut (hope I got it right)
    Phobya LM
    ahh
    and Coollaboratory Liquid Copper (although I think it's silicon based)
    cool
    thx Kyle
    :D
  17. Kyle_Bennett
    48,957
    May 18, 1997
    You just need the right chemicals. :) 99% isopropyl usually works very well. If not, you can go with some things that are a bit more harsh. Also the block I am using is mirror finished.
    Oppy and Peter2k like this.
  18. Peter2k
    Peter2k Limp Gawd
    340
    Apr 25, 2016
    can be a hassle lapping a CPU DIE:ROFLMAO:
    but I saw youre gonna put the lid back on
    still lapping the cooler/IHS every time something like this happens, Ugh.
    glad its not me having a roundup :LOL:
  19. Kyle_Bennett
    48,957
    May 18, 1997
    No exactly my first rodeo with thermal paste in 20 years of reviewing hardware. I will suffer through it. ;)
    Work smart, not hard.
    https://www.amazon.com/D5S6-Contact-Cleaner-F5S-H6-FaderLube/dp/B00HNV7WI2/
    alxlwson and Peter2k like this.
  20. Peter2k
    Peter2k Limp Gawd
    340
    Apr 25, 2016
    :D
    I also really wonder how much difference on the delidding is from removing the glue under the IHS
    as in the distance between DIE and IHS might be a bit too much, because of too much/thick glue
    you'd be willing to test that? :ninja:
    maybe after removing the glue, just put some of the cheapest most general paste (also easy to remove and not conducting) you can find on, but leave the IHS "swimming" on the CPU when you put it in the board?
    I just ...., wonder if it's really just bad TIM, or the tolerances when it comes to glueing the IHS on are a bit too high
    Folterknecht likes this.
  21. I thought some of those liquid metal compounds were perm set once they harden. So you basically get one crack at it.
  22. Qrash
    Qrash Gawd
    967
    Oct 9, 2014
    Yes, I think this is worth checking as much as the difference between different TIMs.
  23. tikiman2012
    tikiman2012 [H]ard|Gawd
    1,228
    Dec 16, 2009
    The time that I tried the liquid metal TIM it stained my Swiftech water block. Mirror finish was gone. Tried every cleaner & solvent that I had in the garage. Ended up lapping it & giving it a new polish. Just not worth the hassle IMO.
    IC Diamond cuts the shit out of everything. It works great for giving processor dies a matte finish.
    alxlwson likes this.
  24. tikiman2012
    1,228
    Dec 16, 2009
    Depends on the kind you get.
    Deleted member 93354 likes this.
  25. Jim Kim
    Jim Kim 2[H]4U
    3,232
    May 24, 2012
    Can't wait for the results from a reliable site like the [H]ard. Keep up the good work.
  26. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    6,297
    Feb 7, 2003
    +1 for Kyle using the word "smorgasbord" on the front page. :geek:
    wra18th likes this.
  27. Kyle_Bennett
    48,957
    May 18, 1997
    I looked it up to make sure I spulld et curklie.
    Peter2k likes this.
  28. Endgame
    Endgame Limp Gawd
    193
    Jan 10, 2007
    I have a couple of syringes of Swifttech Tim mate 2, but I've never used it. Would love to see if its any good.
  29. Shotglass01
    Shotglass01 [H]ard|Gawd
    1,962
    Aug 26, 2005
    All in on this one. Great work! Can't wait to see how this turns out. :)
  30. CaptNumbNutz
    CaptNumbNutz [H]ard as it Gets
    19,516
    Apr 11, 2007
    I want to see more oddball stuff like the cheese test again. Maybe try different cheeses?
  31. cyclone3d
    cyclone3d [H]ardForum Junkie
    12,840
    Aug 16, 2004
    What about Arctic Silver Ceramique 2 ?
    It is my go-to TIM for laptops and systems I work on/build for others.
    Prime reasons are:
    1. It works well
    2. Is easy to spread
    3. Is cheaper than IC Diamond
    4. Doesn't dry out
    5. I can get it locally
  32. VIC-20
    VIC-20 Gawd
    843
    Mar 24, 2006
    Cheese fails, but why not try Sriracha? It seems to be all the vegan hipster rage these days.
    Kyle_Bennett likes this.
  33. Nenu
    Nenu [H]ardened
    18,579
    Apr 28, 2007
    I'm not sure cabbage will fare very well.
    Peter2k, JDiesel and Kyle_Bennett like this.
  34. Aireoth
    Aireoth 2[H]4U
    2,314
    Oct 12, 2005
    What about that weird 12 second to mount water block from Ncore?
  35. Kyle_Bennett
    48,957
    May 18, 1997
    Well, that is a whole other discussion..
  36. prime2515102
    prime2515102 [H]ard|Gawd
    1,510
    Mar 3, 2003
    Yeah but you only used American cheese. A Velveeta vs. cheddar comparison would be very useful.
  37. Kyle_Bennett
    48,957
    May 18, 1997
    I was thinking smoked Gouda.
    Pandur, GhengisKhan, JDiesel and 2 others like this.
  38. Aireoth
    Aireoth 2[H]4U
    2,314
    Oct 12, 2005
    Your delidding it anyway ;).
    Looking forward to the results, always looking for something crazy to try at home.
  39. Nenu
    Nenu [H]ardened
    18,579
    Apr 28, 2007
  40. Kwaz
    Kwaz Whine & Cheezy
    3,559
    Sep 3, 2014
    Can you add Antec Formula 7? It's a paste I've found is a bit better than the NT-H1, though it is quite thick. Is it possible to test both the spread and X methods for this particular paste? It does not spread well with the pea method, and the instructions advise to um, spread it.
