m3ta1head
777
- Feb 22, 2006
Ok, I'm confused. Car or home?
Nevermind, I dug around the site..Car
Uhhh, a driver is a driver, no matter where you put it. I've installed them in cars and home theaters.
Since it doesn't have a standalone power supply, you're going to have some trouble getting enough power to it.
um, just like in a car you have to buy an AMP to power it. google "plate amp"
Precisely.
You do have to observe impedances though. Many home systems are 8-ohm or 4-ohm tolerant, while typically only automotive amplifiers will tolerate 2-ohm drivers.
(yes, there are exceptions, especially in regard to high-end, aka expensive, home audio components... but the majority of home equipment is what I am referring to)
This is a dual 4-ohm coil.
Run separately (stereo input), be sure your equipment can handle 4-ohm impedance.
If you plan to run the coils parallel-mono (single channel) be sure your equipment can handle 2-ohm impedance.
If not you can run serial-mono. That gives 8-ohm impedance, but your power levels will be lower.
Hmmm, I think I may want to scoop a pair of these...
Well yeah no shit, but now it isn't a bargain - plate amps are expensive. I've made them myself several times, I'm just making note that it isn't a piece of cake to do.
Some much better brands for only a little more money are Ascendant Audio, TC Sounds, Sundown Audio, Sound Splinter. ED subs sound like crap. If slopy Bass is your thing, or you have no ear for SQ or jsut dont give a crap and want to make noise like a teenage kid and you like companies like Audiobauhn then buy ED.
Don't worry, Justin is one of the people that like to perpetuate the shitfest that started at CA.com and SI.net years ago. You won't be disappointed with those drivers.
I saw TC Sounds recommended- did you realize they're no longer in business? Thilo is essentially hiding from everyone who knows him. Ascendant Audio is the same company as Fi now, Sound Splinter doesn't have any availability yet (since TC is gone). Sundown will get you your stuff, and it will be good.
TC sounds is not really out of buisness they changed their name to audiopulse but there prices are too high to recommend them for bang for the buck IMO. My $100 TC1000 was great performance vs $400 JLW6, however the new drivers similar to the $1000 are about as pricy as the W6. I would probably try a new company like sundown audio because I like to try many different things. Don't forget the enclosure can make or break a sub, a $50 in the right enclosure can sound better than a $1000 in a bad enclosure / setup http://www.audiopulse.com/
looks like Sound Splinters went up in cost...
