Zarathustra[H]
Extremely [H]
- Oct 29, 2000
How are the PC13 Ultra's treating you? With the open layout it looks like you're fighting a shitload of area (same as me), trying to decide on building a Marty or splurging on an Captivator 1400
I've been very happy with them. I was definitely compensating for the large open area when I bought them (there is another opening to the left out of frame you can't see) but in retrospect I overcompensated a little bit.
They only have 13.5" drivers, but are tunable with 1000W RMS and three ports each. Per the manual, I ahve them set to 16hz mode, and thus have one port plugged on each, and they provide MORE than sufficient butt shaking during intense films from across the room. Audyssey turned them down quite a bit during the room correction algorithm, but I went in and turned them back up a bit as I thought it sounded better that way.
I'm still only using a tiny fraction of their capability, but I guess I have extra capacity if I ever move to a larger house
While the PC13 Ultra's were likely overkill for me, one thing I definitely recommend is dual subs for a HT setup. I moved my old single sub all over the room and could never find a place where it provided even bass across all seating positions. There was always one seating position with MUCH more bass than the others, and some where it was very underwhelming. Having one sub in each of the front corners of the room, and having them be independently adjustable solves this problem very nicely.
