[H]ard Sff Club
Discussion in 'Small Form Factor Systems' started by Michigan PC, Aug 17, 2005.
  1. Dayaks
    Dayaks [H]ardness Supreme
    6,612
    Feb 22, 2012
    I built a little Sugo 13 build for travel, while on travel, in my hotel room. I got the idea off this forum to hook up a desktop the the hotel TV. Brilliant! I'll probably rebuild when I get my Osmi case and retire this to the home TV and/or NVidia shield (for the kids). The sugo is a nice little case for $40.
    I learned the best way to do a SFF build is CPU -> cooler -> install mobo -> install rad -> front panel wires -> power wires -> install power supply -> install GFX card.
    4690k/970 Turbo/240GB SSD/500 SFX-L
    I liked how you could slide in the graphics card from the front.
    [​IMG]
    Side shot
    [​IMG]
    Completed with Fage as a size comparison.
    ][​IMG]
    It booted!
    [​IMG]
    {NG}Fidel likes this.
  2. Cerulean
    Cerulean [H]ardForum Junkie
    9,244
    Jul 27, 2006
    That's always the most exciting point in time after a build
  3. maclem8223
    maclem8223 Case w[H]ore
    1,422
    Oct 28, 2013
    May I ask what Pioneer optical drive that is and the other portion in the area?...I like the setup and would like to do something similar with my 250D
  4. mICKEL
    mICKEL Limp Gawd
    257
    Mar 16, 2005
    My new rig, an upgrade from my Xeon 5450/LGA 775 system I've had forever.
    [​IMG]
    [​IMG]
    [​IMG]
  5. Xin
    Xin n00b
    2
    Feb 6, 2016
    Have an Intel NUC, that count, right?
  6. Xin
    Xin n00b
    2
    Feb 6, 2016
    I will start my own club with Blackjack and :p
  7. w1retap
    w1retap [H]ardForum Junkie
    11,797
    Jul 17, 2006
    Jonsbo RM3 x99 build soon to be completed. :)
    [​IMG]
    revenant and {NG}Fidel like this.
  8. fx9
    fx9 [H]ard|Gawd
    1,083
    Apr 2, 2008
    I guess I'm joining the SFF club, traded in my full tower for SFF as my New York City apartment is too small for a full tower. So here goes, my Cougar QBX with a R9 290, a Noctua C14, and a Corsair HX620 PSU. You might be wondering how did he fit a 140mm Noctua in there? you're right , it doesn't fit, barely. As you can see the rear power plug is not sitting in the socket, I will need to swap this for a Noctua NH-L12 later. You're also thinking, how did he fit a HX620 which is a 150mm depth psu in the case that was made for a 140mm psu? I modded the case a little, cutting off the lower flange allowed the case to fit this psu.
    [​IMG] [​IMG]
    [​IMG]
    Next to my full tower for comparison
    [​IMG]
    Quartz-1 likes this.
  9. ledcriss
    ledcriss Limp Gawd
    151
    Dec 15, 2014
    I made the switch a few months ago to a nice Lian Li SFF / EVGA GTC 980ti, Intel i5 6600k, ASRock Z170, Samsung 850 EVO 500GB, Lian Li PC-O5SX, 2x Noctua NF-F12, 8gb 2400 DDR4, Silverstone SX600, 1x Noctua NF-A14 and the beautiful Swiftech H220
  10. tracer11LB
    tracer11LB [H]Lite
    112
    Feb 11, 2016
    So if I put a Gigabyte brix inside a SFF case, can I join? :)
  11. Quartz-1
    Quartz-1 [H]ardness Supreme
    4,329
    May 20, 2011
    So it's the cooler itself blocking the power plug, not the fan?
    I'm surprised you didn't take the opportunity to get a nice modular SFX or SFX-L PSU.
  12. fx9
    fx9 [H]ard|Gawd
    1,083
    Apr 2, 2008
    Yes it was the cooler itself blocking the power plug from the inside of the case. After swapping it for the Noctua NH-L12 it fits fine.
    I opted not to use a SFX psu as I had issues with noise and QC from Silverstone in the past. The next best thing was to mod the case itself with a hand nibbler tool.
  13. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    5,838
    Jan 17, 2005
    Ncase m1 on the way. My 250d X99 puts me in the club though
  14. rat
    rat [H]ardness Supreme
    4,930
    Apr 16, 2008
    Ended up doing a casemod on my EVGA Hadron Air to fit a standard PSU in it to replace the stock 1U one.
    Aside from the lousy placement of the ATX connector, it turned out pretty well.
    [​IMG]
  15. D mo T raz
    D mo T raz n00b
    21
    May 25, 2016
    list add? will upload pics soon but builds are in the signature
  16. {NG}Fidel
    5,838
    Jan 17, 2005
    I finally join the true PC Master race guys. Feels good to be here! 4.1GHZ (4.098 :( close enough) 5930K and a R9 390X soon to be upgraded to whichever next gen GPU earns its spot to replace it!
  17. drklu
    drklu 2[H]4U
    2,074
    Jul 15, 2013
    [​IMG]
    [​IMG]
    Built this a while ago, great case to build in. Now I just need a water cooled Pascal card to throw in it
    revenant and fx9 like this.
  18. fx9
    fx9 [H]ard|Gawd
    1,083
    Apr 2, 2008
    That 450W Silverstone PSU is beefy enough to power that video card? I hear the gtx 680 needs a 550W psu, maybe cause its a mini itx mobo.
  19. drklu
    drklu 2[H]4U
    2,074
    Jul 15, 2013
    Never really had issues with it, at the time it was really the only option. I have even OC'ed the CPU/680.
  20. NeoMatriX724
    NeoMatriX724 Limp Gawd
    269
    Jul 26, 2007
    I Would Like to Join! Introducing Mjolnir!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    AceGoober and {NG}Fidel like this.
  21. rat
    4,930
    Apr 16, 2008
    Fuck! Making my Hadron Air looking positively spacious. Nice job.
  22. {NG}Fidel
    5,838
    Jan 17, 2005
  23. TheLAWNoob
    TheLAWNoob Limp Gawd
    341
    Jan 10, 2016
    Laptop's screen broke so I hooked up 2 monitors and using it as my main rig.
    Am I doing this right?
  24. SQX_Barto
    SQX_Barto n00b
    23
    Mar 22, 2012
    Finally, I'm in the club! :)
    IMG_20160713_200202.jpg IMG_20160713_200425.jpg IMG_20160713_200431.jpg IMG_20160713_200446.jpg
    Antec ISK 600|Gigabyte GA-B150N Phoenix-WIFI|Intel Core i7-6700|XFX Radeon RX 480 8GB|Kingston FURY 16GB (2 x 8GB) DDR4-2400|Kingston HyperX Fury 240GB 2.5" SSD|Cooler Master G550M|SteelSeries Rival 100|Steelseries QcK+|Kingston HyperX Cloud II 7.1 Headset
  25. sparky1_2007
    sparky1_2007 2[H]4U
    2,872
    Jan 15, 2005
    I'm now a member of the SFF club.
    did a quick mod to remove the HDD cage as I don't need it
    sorry for the potato quality pic
    [​IMG]
  26. rat
    4,930
    Apr 16, 2008
    Since I have to move soon I finally ended up finishing out the mods for my EVGA Hadron Air.
    [​IMG]
    [​IMG]
    Ended up installing a 2.5" dual hotswap bay to 3.5" adapter and facing the front end of the bay where the 1U PSU used to be so I can swap out the SSDs in my system without needing to open the case.
    Had a GTX 580 OC in there before, replaced with a nice (and much cooler) GTX 970 ITX OC.
  27. Outlaw85
    Outlaw85 Gawd
    728
    Feb 7, 2012
    Been built a while but just found this thread. Is it still going and do I qualify?
    [​IMG]
    revenant likes this.
  28. sparky1_2007
    sparky1_2007 2[H]4U
    2,872
    Jan 15, 2005
    got some cable extensions for the Hadron Air, they make a world of difference in cable management!
    After:
    [​IMG]
    [​IMG]
  29. theplaidfad
    theplaidfad Lurker
    1,048
    Apr 24, 2008
    Well, if the system in my sig counts... I'll post up a couple of photos. I just finished it 3 weeks ago.
    The case is an itx case by name only, seems large compared to others in this thread. I had to make sure what I already had would fit so I didn't take any chances going smaller.
  30. nwkrep82
    nwkrep82 Limp Gawd
    167
    Oct 18, 2011
    CASE - Wesena ITX4 v3
    CPU - Intel Core i3 6100
    MOTHERBOARD - Gigabyte GA-Z170N-WIFI
    MEMORY - Crucial Ballistix Sport LT 8GB 2 x 4GB DDR4-2400
    CPU COOLER - Noctua NH-L9i
    CPU COOLER FAN - Noiseblocker NB-BlackSilentPro PE-P 92mm x 25mm Ultra Quiet PWM Fan - 1800 RPM
    CASE FAN - Noiseblocker NB-BlackSilentPro PC-P 80mm x 15mm Ultra Silent PWM Fan - 2500 RPM
    POWER SUPPLY - picoPSU-160-XT (custom sleeved), 160w output, 12v input DC-DC Power Supply (192w AC-DC Power Adapter, 12v 16A)
    STORAGE - SAMSUNG SM951 M.2 128GB
    GRAPHICS - MSI N750 TI-2GD5TLP w/retrofitted cooler from EVGA Geforce GT 730 2GB (low profile) - cooler and PCI bracket PlastiDip black for a stealthy asthetic.
    OPERATING SYSTEM - OS X EL Capitan
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    revenant, raymondo and {NG}Fidel like this.
  31. {NG}Fidel
    5,838
    Jan 17, 2005
    Beautiful work. I keep toying with the idea of making a Hackintosh box
  32. nwkrep82
    nwkrep82 Limp Gawd
    167
    Oct 18, 2011
    Thanks :D
    I was also toying with the idea for a few years actually...Recently, I just decided to do it. With all the amazing guides out there, it wasn't difficult at all. The most 'difficult' part was getting my hands on a Mac to start the whole process (No one I know owns one). I ended up just buying a Macbook to start the process and then returned it a few days later...
  33. w1retap
    11,797
    Jul 17, 2006
    Why would you need a Mac? Every one I've made never required one to start with.
  34. {NG}Fidel
    5,838
    Jan 17, 2005
    Was about to ask that question, I had no idea you needed a Mac for certain methods.
  35. nwkrep82
    nwkrep82 Limp Gawd
    167
    Oct 18, 2011
    Let me rephrase that...There are ways to do it without a mac (Niresh or set up a Mac Virtual Machine, for example). However, since the more 'popular' and tested guides at the time used a Mac, I decided to go that route.
  36. w1retap
    11,797
    Jul 17, 2006
    Oh, I just used a virtual machine to export the latest disk image. It was super simple. (probably a lot faster than buying a Mac and returning it lol)
  37. nwkrep82
    nwkrep82 Limp Gawd
    167
    Oct 18, 2011
    Yeh definitely a lot faster...LOL. The guide I used even had the same motherboard with all the little hackintosh hiccups all figured out. For a first timer, using it was a no brainer LOL
    The next one I do (or two..I have a couple people who want me to build one for them), I'll definitely use one (or both) of the aforementioned methods. I like to try different ways to do things.
    w1retap and {NG}Fidel like this.
  38. Homey D. Clown
    Homey D. Clown Limp Gawd
    209
    Sep 27, 2004
    [​IMG]
    Gun_metal Plasti-Dipped
    Phanteks Enthoo Evolv iTX I have a pair of red led fans coming to replace the white ones. AMD 7890K Apu, 16Gb Crucial Ballistix 2133 Ram, 4 SSD's running in raid 10, MSI A88XI AC V2 motherboard. It plays overwatch at high settings great!
  39. Raendor
    Raendor Gawd
    857
    Sep 21, 2015
    Finally, please welcome my Node 202 build. Right now it's a simple g4560 + 1050ti combo in its heart, but at has everything ready for future upgrades.
    Full info on https://pcpartpicker.com/b/HNP323
  40. sparky1_2007
    sparky1_2007 2[H]4U
    2,872
    Jan 15, 2005
    Recently updated some stuff in my case:
    New GTX 1080ti to replace the old 1070 I had in there for a while
    New CPU cooler - Nocuta NH - L12
    New CPU - 7700k
    [​IMG]
    {NG}Fidel and caddys83 like this.
