[H]ard Sff Club
Discussion in 'Small Form Factor Systems' started by Michigan PC, Aug 17, 2005.
  1. saxovtsmike
    saxovtsmike n00bie
    10
    Mar 18, 2012
    Final Pics
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Robertmarcus
    Robertmarcus Gawd
    671
    Jun 4, 2012
  3. jojo69
    jojo69 [H]ardForum Junkie
    10,346
    Sep 13, 2009
  4. rwpritchett
    rwpritchett n00bie
    40
    Jul 9, 2011
    Hey SFF club, check out what's coming from EVGA. The Hadron:
    [​IMG]
    Looks like we have a challenger to the Prodigy as the best ITX gaming chassis.
    http://www.evga.com/articles/00777/
  5. rat
    rat [H]ardness Supreme
    4,930
    Apr 16, 2008
    Deleted.
  6. rwpritchett
    rwpritchett n00bie
    40
    Jul 9, 2011
    It comes with a Gold rated 500W.
    Looks like a flex ATX unit.
  7. tonyftw
    tonyftw [H]ard|Gawd
    1,821
    Mar 21, 2013
    The case comes with its own psu (500w - 80+ gold rated). It's available for $189.99, so it is not cheap.
  8. rat
    4,930
    Apr 16, 2008
    Deleted.
  9. saxovtsmike
    saxovtsmike n00bie
    10
    Mar 18, 2012
    Better Pics I made outside
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Plans :
    Abusing the system, Making a propper mount for the SSD´s on the CPU Side, Cleaning up the wires.
    Maybe I ditch the rear mounted Quickcouplers as by now the internal cooling capacity with a slim 140 and a 45mm thick 240 Radiator is sufficient.
  10. Alted4
    Alted4 n00bie
    56
    Nov 20, 2011
    I emailed EVGA about it. Apparently it is sourced from FSP Group and is the same model as this one, just painted black. So while not a realistic option, replacement it for another is possible. FSP does offer 600 and 700 watt versions, but they are longer than the 500 watt version, and might not be compatible (not to mention restricting airflow).
  11. hyp36rmax
    hyp36rmax n00bie
    56
    May 16, 2013
    #beastMODE
    Silverstone TJ08-E and SG05
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  12. StanRex
    StanRex n00bie
    11
    Jun 13, 2011
    Hello,
    I'm currently the owner of a SG07, pretty happy with it.
    But I've become a bit obsessed with SFF and making my rig as light and small as possible, while still keeping it pretty powerful.
    So I've taken a look at the contents of my SG07 :
    Mobo
    Gaming CPU (2500k in my case)
    "Enthusiast/performance" graphic card
    PSU
    AIO cooler (antec 620)
    Storage (1 HDD and 1 SSD)
    1 big fan to make the case breathe
    (theorically I'm not using all the space available as there was still space for 1 more 2.5' storage device and a slim optical drive, but things feel pretty cramped already)
    Now, I can't help but think I should be able to make things even smaller, while retaining 99.9% functionality for gaming, if I moved to :
    a SFX PSU instead of the ATX used in the SG07.
    Removing the SSD/HDD combo and going for a 480gb msata SSD. I'm thinking 480gb should be quite enough for gaming needs in the next years, as videos/docs are mostly stored on a NAS
    I'm just curious if someone has tried this before (going totally without 2.5/3.5 drives), and if they designed a specific case to get things as small as possible, maybe using a riser ?
  13. dmoney1980
    dmoney1980 Limp Gawd
    465
    Oct 10, 2011
    hyp36rmax - how are the temps and noise levels in that SG05? Any what kind of psu are you using?
  14. Quartz-1
    Quartz-1 [H]ardness Supreme
    4,329
    May 20, 2011
    It's a standard 1u server PSU, just not ATX or SFX format. Shuttle have used them for years.
    FSP do a whole range of them up to 700W - see here.
  15. hyp36rmax
    hyp36rmax n00bie
    56
    May 16, 2013
    The temps are pretty good: CPU is 30-35 C and GPU is 64-69 C at load. It's not very loud at all. I'm using the Silverstone ST45SFG 450Watt Gold Modular PSU. I'll have updated numbers and a more detailed analysis once I get my water-block for my GPU.
  16. edward78
    edward78 Limp Gawd
    234
    Aug 21, 2011
    What case is that?
  17. ekuest
    ekuest [H]ardness Supreme
    6,099
    Feb 23, 2009
    iirc that is a heavily modified bitfenix prodigy.
  18. edward78
    edward78 Limp Gawd
    234
    Aug 21, 2011
    Cool, that case having the odd handle thing around the case is annoying. Is is hard to take the handle thing off? What are the measurements of yours?
  19. ekuest
    6,099
    Feb 23, 2009
    i dont remember. it's not my build, i just remember reading his build log a while ago. if you want to check it out here's a link: http://hardforum.com/showthread.php?t=1778130&highlight=
  20. Blorgon
    Blorgon Limp Gawd
    361
    Jun 29, 2014
    The handles are easy to remove, but the handle mounting holes are exposed when you do this, and it looks awful. It looks like those are custom side panels.
    [EDIT] oops. Looks like a link was posted to the build. Go check it out.
  21. Kramler
    Kramler n00bie
    11
    Sep 7, 2012
    Just finished this the other day. I wanted to try the matx for a lan pc, and with a older platform(s775)
    [​IMG]
    Hardware is in signature
  22. Tyler-Durden
    Tyler-Durden 2[H]4U
    2,303
    Nov 18, 2012
    I'm new to the club with my new ITX build.
    Corsair 250D
    Asus PZ97I-Plus
    Intel i5-4690K
    Corsair H100i (my first time with water cooling was surprisingly easy)
    eVGA GTX 980
    Corsair Vengeance 16GB 1866
    Samsung 840 Evo 500GBx2
    WD Black 2TB 7200RPM
    Corsair AX760i
    [​IMG]
    Been installing software and transferring files all day... and it's gonna be a long night of it, too. :p
  23. Kramler
    Kramler n00bie
    11
    Sep 7, 2012
    I shouldn't be dissing, but mate, its easy enough when you buy a closed system. Try and buy all the parts alone, and then try to get 'em to fit. Or find out that parts don't fit fit together. THAT is hard(kinda).
    Just putting in the rad, and mount the cooling head, thats nothing.
    Although i would say that closed systems they have come with the last couple of years, looks really nice, and they practically the same
  24. anon
    anon Limp Gawd
    154
    Jan 26, 2011
    Anyone have a Thermaltake Core V1 build pics?
  25. Nickbaldwin86
    Nickbaldwin86 2[H]4U
    2,139
    Nov 8, 2009
    Just started modding it a few weeks ago:
    Corsair 250D
    Asus H97
    i5-4440
    Corsair XMS3 8GB
    AMD HD 7970
    Corsair RM750
    2xCorsair LS128GBSSD RAID0
    2xWD1.5TB
    [​IMG]
    [​IMG]
  26. hyp36rmax
    hyp36rmax n00bie
    56
    May 16, 2013
    The progress of my Silverstone TJ08-E Rebuild #Phase02
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Build Log: Link
  27. ThoseSneakyFrench
    ThoseSneakyFrench n00bie
    32
    Dec 12, 2010
    I've been a long fan of densely built systems. I see too many otherwise great cases, that are just a lot of empty space on the inside. I recently did a build for a lab I work at, and I have to recommend the Silverstone Precision PS09B for cheaper builds.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811163247
    I was impressed by the build quality,price, and that it is a case that isn't any bigger than it needs to be.
  28. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    How much was it?! Pretty nice for being so small! I like the way they lay everything out in the tiny case.
  29. Cerulean
    Cerulean [H]ardForum Junkie
    9,231
    Jul 27, 2006
    Gigabyte Brix GB-BXi7G3-760 (800 USD shipped)
    Crucial 16GB (2x8GB) DDR3 SODIMM kit (120 USD shipped)
    Samsung EVO 840 250GB mSATA SSD (120 USD shipped)
    Total: 1040 USD shipped
    Already have Windows licenses so that doesn't factor into total cost, but you could easily get a Microsoft Windows 7 Professional license from someone here for about 55 USD.
    I also put a Kingston HyperX 120GB 2.5" SSD in it as well to use for TMP and TEMP system variables + user profile AppData location. Got this SSD from a laptop that I put an 80GB Intel SSD in.
    This tiny thing can run Skyrim at 1920x1200 on maximum quality settings and still give me smooth superfantastic framerate.
  30. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    Play any newer games on it?
  31. Cerulean
    9,231
    Jul 27, 2006
    Not yet. Far Cry 4 is on the list though -- bought a copy from an [H] member. Need to download and install.
  32. ekuest
    6,099
    Feb 23, 2009
    i think i heard they were pretty loud. is it bad at high load or pretty bearable?
  33. Cerulean
    9,231
    Jul 27, 2006
    I personally find it quite tolerable.
  34. Cerulean
    9,231
    Jul 27, 2006
    I did the first mission of getting to the tower as a speedrun and kept it mostly the same pathway. Not perfect but that's OK; for practical purposes this is sufficient. By default, it selected 1920x1080 for my resolution and the "High" profile.
    1920x1080 on "High"
    Minimum FPS: 30
    Maximum FPS: 58
    Average FPS: 43
    Then I would change the video profile, restart the mission, and do it again
    1920x1080 on "Very High"
    Minimum FPS: 26
    Maximum FPS: 51
    Average FPS: 37
    1920x1080 on "Ultra"
    Minimum FPS: 24
    Maximum FPS: 50
    Average FPS: 34
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  35. ThoseSneakyFrench
    32
    Dec 12, 2010
    Just got a Lian-Li PC-Q28B, I'm going to put my build in it this weekend. Anyone have experience with this case?
  36. Alexke
    Alexke n00bie
    22
    Dec 2, 2010
    So can I be a member ? Sorry for the bad pics :p
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Sorry for the bad pics will make some outside soon...
    Specs :
    i5 4670k @ 4.0ghz
    Corsair H100i
    8Gb Ram 1866mhz
    512Gb Crucial M100
    2 x 2Tb Green
    280x Sapphire
    Kraken G10 with H75
    Stays really cool!
    gaming GPU temps stay around 45c !
    Build For Lan Partys
  37. rat
    4,930
    Apr 16, 2008
    Way back in the day (in Internet time) I demonstrated a mod on here to turn an XBox 360 203 Watt PSU into a secondary power supply for the video card. I was running a GTX 275 at the time.
    [​IMG]
    http://hardforum.com/showthread.php?t=1712969
    I tried other SFF setups that would allow me to go back to using a single PSU, such as the Fractal Node 304 case, but kept coming back to my trusty Shuttle box. Hard to beat having 4 RAM slots in a SFF build. (Does anyone still do this anymore or is everything mITX 2 RAM socket now?)
    [​IMG]
    Few things have changed since then. I've become heavily involved in the video and graphics department at the studio and that requires more resources. More ram (hence the Shuttle), more space and power in general.
    I rebuilt my Shuttle to go from an Athlon II x4 630 2.8Ghz to a Phenom II 1055t x6 2.8/3.3Ghz CPU. Honestly, I could have skipped that part. Video rendering is dog slow on a CPU, no matter how you slice it. 50% improvement over a handful of hours is still several hours waiting for it to be finished.
    Had to give up my GTX 275 because of a Steam/DirectX bug that caused unresolvable crashes. Got a 640GT on sale because it required no additional power, had CUDA support and 2GB Ram which was perfect for the Shuttle as it only has a 250Watt PSU.
    Unfortunately, After Effects won't use a GT 640 (despite having 384 CUDA cores) for GPU Raytrace Rendering, so I picked up a used GTX 470 (one of the cards specifically mentioned to be supported by AE) from another member on the HardForums and resurrected my XBox 360 PSU.
    XBox PSU still runs great.
    [​IMG]
    Due to my triple fan setup, temps almost never break 100f internally. Only the GPU breaks 100f and at the most, it hits about 120-130f. Direct side fan does the trick.
    Because of how nice it is to have GPU Rendering when using apps like After Effects, I decided to cobble together my spare parts into a new SFF build to use only as a render box for projects in the studio instead of at home. It would cut our Mac Pro (12 Core Xeon based) rendering times from 2 1/2 hours to about 10 minutes at the same quality level. Just getting to minutes within a deadline by the time something finishes rendering can be a big headache even when you plan for that kind of overhead. We don't do enough easy breathing and I want to change that.
    [​IMG]
    Some of you folks may have seen this case making the rounds. It's a generic/white box design being branded and resold by some case brands. Usually DIYPC and Raijintek.
    http://www.eteknix.com/raijintek-metis-mini-itx-aluminum-chassis-review/
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811353044
    The case has some flaws. But it's also probably the best compromise between size and utility that I've seen yet. I always felt the Node 304, while a really, really nice case... just didn't make use of its internal space all that well. This case also uses discrete panels for the sides, which I've always preferred over the single piece "U" shell type cases.
    [​IMG]
    Case is actually a lot roomier than it looks from the outside. My A8-5500k is in there with an MSI mITX Mobo. Soon another GTX 470 will be in there along with my Antec 620W PSU. Plenty of room for both, which is nice. Nothing's installed yet since my PSU is currently tied up powering a failing NAS box being backed up to another external drive. Sigh.
    [​IMG]
    Proportionately, it's about as wide and about a third taller than my Shuttle box while being slightly less deep.
    Can't wait to see the looks on some peoples' faces at the studio (I train a lot of interns that don't know any better) that my sub $300 build is going to kick the snot out of the Xeon Mac Pros in render time. Box will be headless, network accessible and used via TeamViewer exclusively for rendering finished projects... So largely transparent as people will still be using the Mac Pros for content creation itself.
    Specs for Shuttle:
    Phenom II 1055t x6 2.8/3.3Ghz 95 Watt CPU
    Shuttle XPC AM3 based Barebones Box with 250 Watt PSU
    24GB Ram DDR3 1333
    30" Apple Cinema Display (DVI)
    EVGA GeForce GTX 470
    120GB SSD, 500GB HDD dual mounted behind the fan controller
    Some 10-odd TB of Disk Space slowly being recovered (sigh)
    Specs for DIYPC Box:
    MSI FM2-A75IA-E53 mITX FM2 Motherboard
    A8-5500k 65 Watt APU
    2GB Ram (for now)
    320GB HD
    Asus GeForce GTX 470
    Antec Neo Eco 620W
    Having the DIYPC case in my hands, feeling it and working within it... I think it's now my go-to case for mITX builds. They did a lot of things right with it and SFF cases without visible drive bays are sorely lacking. Design may be a bit spartan compared to what gets posted here but that's exactly why I like it.
  38. toyz72
    toyz72 Limp Gawd
    318
    Feb 14, 2010
    i'm getting ready to start my itx build ,but having some trouble deciding on a good budget board. i been looking at the gigabyte z97n gaming 5,and the asus z97i-plus. anyone have experience with these boards?
  39. silencer51
    silencer51 n00bie
    44
    Aug 28, 2008
    I have always used huge cases for my builds. For the past 10 years or so, I'd been using a CM Stacker 810 (the original) for my main rig.
    Last year, I got hold of a Coolermaster Elite 130 from a friend, and I thought, 'why don't I build an itx system!'.
    Fast forward a couple of months later... The Stacker is no more (sold), and now my main rig is housed in a Corsair Obsidian 250D.
    I don't think I'm going ATX or even mATX ever again. :D
    Here are a couple of crappy tablet pics from my build:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    And a wide shot of the desk:
    [​IMG]
    I'm using the following:
    i7 4790k
    Asus Maximus Impact VI
    2x8GB low profile Crucial DDR3L at 1600Mhz
    Nvidia Geforce GTX 780Ti
    Samsung 840 Pro 512GB
    ADATA SP900 128GB
    Seagate 4TB HDD
    a Pioneer slim (laptop style) optical drive
    I've gone the tried and tested air cooling route: Corsair case fans all around and a Noctua NH-L12 for the CPU with a push-pull setup (120mm and 90mm fans).
    I used my s1366 rig's 1KW Corsair PSU (overkill, I know, but it fit perfectly inside the little Corsair case and it just works!).
    I kept the Elite 130 case and I'm itching for another ITX build - perhaps AMD flavored... We 'll see.:)
