Guys I have waited long enough...I need help
Discussion in 'Intel Processors' started by sparks, Jan 7, 2017.
  1. sparks
    sparks 2[H]4U
    3,206
    Jun 19, 2004
    first I was looking at 5820K or 6700K.
    May wait for Broadwell prices will drop .Hell no they didn't
    then we had 5820K vs 6800K vs 6700K and I was more confused.
    Now its 5820K vs 6800K vs 6700K vs 7700K
    I do not edit videos or audio files. I play games and the usual desktop crap.
    What should I get???
    Ps I picked up a corsair 110gt cooler for dirt cheap during Christmas sales now I find out the radiator is huge, what case?
    thanks for advice
  2. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    6700k or the 7700k since it's newer and has a better memory controller.. grab a z270 mb for it.
    No idea on the case.
    More then 4 cores would only be needed for video editing and crap. Games need fast mhz and that's the 6700k or 7700k.
    Peter2k likes this.
  3. wareyore
    wareyore Limp Gawd
    218
    Jan 1, 2014
  4. Shintai
    Shintai [H]ardness Supreme
    5,691
    Jul 1, 2016
    7700K+Z270.
    drklu likes this.
  5. HDriscoll
    HDriscoll Limp Gawd
    416
    Jun 18, 2012
    For a case I'd say the 750D from Corsair. I have the H110i cooling my i7 5960X (X99 platform).
    I don't like the stock fans however, one case fan died and one for the H110i was making a bunch of noise.
    I replaced all 5 fans.
  6. sparks
    sparks 2[H]4U
    3,206
    Jun 19, 2004
    I looked at their chart and its not a true recommendation at all.
    I have a 500R and it says it will fit 240 radiators but mine won't even fit a 100 cooler with a full size atx board.
    The fans won't fit because of the top 8 pin header.
  7. thesmokingman
    thesmokingman [H]ardness Supreme
    4,887
    Nov 22, 2008
    Look at something from nzxt to phantek.
  8. skeeder
    skeeder [H]ard|Gawd
    1,316
    Jul 9, 2004
    the i5 version of the kaby lake.
    Just saying, I doubt you'd notice a difference in your tasks. Put that extra $100 into video card.
  9. Guarana [BAWLS]
    Guarana [BAWLS] [H]ard|Gawd
    1,787
    Oct 3, 2001
    My case Vote is for a Phanteks Enthoo Evolv. It's smexy.
    As for CPU? 6700 or 7700, depending on pricing.
  10. RazorWind
    RazorWind 2[H]4U
    3,282
    Feb 11, 2001
    7700K.
    The case is subjective, and will be influenced by what motherboard and graphics card you end up with. Assuming normally sized components, this is a good option.
    http://www.newegg.com/Product/Product.aspx?item=N82E16811146218
    There are plenty of other options. Look at Fractal design if you're more of a "plain black box" man.
  11. UnrealCpu
    UnrealCpu 2[H]4U
    2,736
    Jun 20, 2003
    get at least 6-8 cores , star citizen best game of the decade
  12. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    Damn just checkes that out. Pretty damn nice looking game!
    Can one play it with a quad core 6700k at 4.8ghz and 1080 sli?? Does sli work with it?
  13. UnrealCpu
    UnrealCpu 2[H]4U
    2,736
    Jun 20, 2003
    i guess you didnt look at the developers hardware requirements. If you want to take full advantage of the game get broadwell-E or have more than 4 physical cores
    This game aint no console port
  14. Lunas
    Lunas [H]ardForum Junkie
    9,847
    Jul 22, 2001
    Wait for zen see how that plays out maybe it could trigger a deal to get a discount i7 or a price cut
  15. UnrealCpu
    UnrealCpu 2[H]4U
    2,736
    Jun 20, 2003
    maybe so.. no one knows
  16. Shintai
    5,691
    Jul 1, 2016
    What decade? :D
  17. /dev/null
    /dev/null [H]ardForum Junkie
    14,147
    Mar 31, 2001
    Get an E5-1650 on ebay or maybe a used SB/Haswell box for sub $300 & plow all the rest of the money into a videocard.
