I have a gaming rig and have installed windows 8.1, I was wondering if anyone knows of a guide to get it fully optimized.. stuff like performance settings, bloatware removal ect ect
Get an SSD drive if you're not currently using one.
I don't know why a gaming rig would need a full-blown Start menu. Games aren't exactly something you need to (or should) dig multiple levels for. One of the things I like about Win8.1's Start screen is hey, there's all my games, right there, as big icons. Even my Steam games. Click -> play.classhell.jpg
Disable hibernation, disk indexing, windows defender, system restore. Set UAC slider all the way to the bottom. Set fixed min/max pagefile. Set windows updates to manual. Go to power settings, make a custom profile for high performance. Uncheck remote registry. Enable ClearType for your LCD panel.
I know you may feel like you're getting more by disabling services or making a bunch of changes, but the truth is the default instal is optimal for any configuration, especially with 8. The only changes you may want to make are to save space on an SSD, if your using one. Disable hibernation file, use the min/max method for the pagefile and disable system restore are great space savers.
It actually bothers me how fast and smooth my Windows 8.1 system runs. The only thing I can't figure out is why is takes forever to restart (eternal spinning circles), but I do that so rarely that I haven't bothered to really diagnose it.
