[Guide] How to remove the anti-glare(AG) coating from a Dell U2312HM LCD
Discussion in 'Displays' started by cre3d, Feb 17, 2012.
  1. Izaq
    Izaq n00b
    1
    Mar 20, 2014
    I just did the mod on my Dell U2412M. It worked perfectly. I ran a trial on my Samsung P2250 first to practice. No problems here.
    I soaked the Dell U2412M for a little less than 4 hours until the bottom right corner of the AG coating could be lifted without using force at all. Then I could smoothly roll off the coating in a bottom-right to upper-left-corner directed steady slow pull. A few times the coating was stuck and I had to wiggle a bit to get it moving again. This left som uneveness in the residual glue (thin lines), but these lines are only visible when the monitor is powered off and when the screen is viewed from the side with strong lights on it.
    It was a succes I would say. The panel is sharper now. Colors haven't changed that much really, but I got rid of the annoying "greying" of the surface when light from the window or a lamp shines on the surface at an angle.
    Nice post OP! :)
  2. icor1031
    icor1031 [H]ard|Gawd
    1,268
    May 29, 2010
    Posted in the wrong thread.
  3. INEEDHELPPLZ
    INEEDHELPPLZ n00b
    8
    Sep 1, 2013
    Bumping this because I want to try this on a TV.
    Would anyone know if this method would be any different on a 65" TV?
  4. Nodrod
    Nodrod n00b
    1
    Feb 14, 2015
    Signed up here to share my results with this guide on my Asus VG248QE, it worked flawlessly. I was patient the let the towels saturate for about 10 hours, I really wanted this to work on my 2 month old monitor :eek:. Here's a few pictures I took during the process. The AG is like a brittle vinyl sticker, it decided to tear on me a few times but the pieces still came off with ease! Thanks for the guide!
  5. androsforever
    androsforever [H]Lite
    97
    Nov 23, 2013
    Nice work! Looks really good. I successfully did that with my Qnix qx2710, and tried to do that even with my Eizo fg2421. On the Eizo I left the towels on for 6 hours but the ag didn't peel at all after that period of time. Would going for 10 hours make a difference? Might give it another try.
  6. punkmanmatthew
    punkmanmatthew Limp Gawd
    157
    Dec 11, 2006
    Would this work on the Dell 2415q?
    It would be nice to be able to actually use the 4k display.
    Thanks
  7. nightanole
    nightanole [H]ard|Gawd
    2,016
    Feb 16, 2003
    The only way this technique would not work is if the monitor had a spray on AG coating and not a film. I have not found one spray on coating yet. It just seems way to time consuming to come up with a new way of putting on a coating vs industry standard of a water permeable film.
  8. Pechendko
    Pechendko Limp Gawd
    208
    Jan 18, 2012
    Would be great to see a comparison before and after dematting.
  9. chenw
    chenw 2[H]4U
    3,977
    Oct 26, 2014
    I wonder if this works on PG278Q...
  10. AdamLuna
    AdamLuna n00b
    1
    May 20, 2015
    delete
  11. neocmetal
    neocmetal n00b
    28
    Jul 21, 2013
    You can buy screen protectors here http://www.photodon.com/
    I removed the ag coating from my benq gw2450 and I plan on buying a screen protector so I don't have to worry about damaging the display.
  12. Vesqwi
    Vesqwi Limp Gawd
    377
    Sep 9, 2011
    anyone here intend on getting an PG279Q and remove the ag coating.
    I'd love to hear if such a process can be done when that baby come up for sale..
  13. Andyk5
    Andyk5 [H]ard|Gawd
    1,154
    Jul 27, 2011
    How would this work on a UP3214Q?
    For the last year, I have this beautiful 4k IPS 32inch monitor and the AG is driving me nuts. I feel like I am looking through a dirty windshield of a car.....I would pay money to get this thing done if the person was in LA.
  14. Bran187
    Bran187 n00b
    1
    Oct 12, 2015
    Sorry for the thread necro, but I had to stop by and say thanks for this awesome guide! It worked like a charm.
    I recently acquired an LG 27EA33 for basically free, the only problem was it had significant scratches on the display. I was pretty certain that they were limited to the AG layer and so the plan was to have a go at removing it (and since the monitor was basically free I was okay with the idea of gambling its potential sacrifice to the silicon gods).
    So following this guide I soaked the screen from five hours, and the AG peeled right off leaving no trace of any glue or residue! I now have a beautiful glossy scratch free monitor and couldn't be happier! A day in and so far no problems (fingers crossed). I am hoping that if I take great care/caution when I clean it and move it that it will have a long, happy, and glossy life. :D Thanks again for the guide!
  15. cre3d
    cre3d Limp Gawd
    487
    Aug 25, 2004
    Thanks for taking the time to post your positive experience! I typed this response whilst watching some ted talks on the very same monitor used to create this guide :)
  16. LunaBoom
    LunaBoom n00b
    1
    May 24, 2016
    Thank You so much! My 6 Year Old Dell 2209W was full of scratches. Now its like a brand new monitor no glue left. ;)
    cre3d likes this.
  17. iRUSH
    iRUSH Gawd
    758
    Jun 4, 2013
    Oh boy I really need to do this on my Dell S2716DGR.
    Matte finish doesn't do it for me.
  18. natz
    natz n00b
    8
    Feb 21, 2015
    Would this work on a U2415? I scratched mine and it's driving me freaking nuts. This might be a solution.
  19. eadgce
    eadgce n00b
    5
    Mar 4, 2017
    I just did this on my U3011. Soaked for 5 hours and the film peeled right off. I have had this display for 4 years and was getting ready to unload it later this year anyway so I figured meh, what the hell? I had always dreamed of doing it to this monitor and since I already got my 'fair share' of use out of it, the worst case scenario is that I'd be out a few hundred bucks at this point. It ended up being time consuming but went smoothly with the exception of accidentally bending some of the ribbon pins when I was disassembling. I had to use a needle to re-seat the bent pins which was lots of fun. I feel the risk was worth it at this stage, and might well regret not doing it sooner. It really looks like a totally different display.
    Peeling the AG coating:
    [​IMG][​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Blubikins and natz like this.
  20. MagnaMagicBtu
    MagnaMagicBtu [H]Lite
    96
    Jan 1, 2017
    Something I've noticed is that only TN and PLS panels can have the AG removed without getting the graining issue. If you remove the AG on an IPS panel and try to clean the glue residue off (for some weird reason) the polarizer starts splitting and cracking like strands. I did 2 IPS panels and they both grained up and are ruined. Did 3 other monitors which were 2 TNs and a QNIX Samsung PLS and the polarizer was very durable, it did not grain no matter how hard I cleaned it while IPS panels started splitting and cracking after just barely touching it. My only theory on this is that IPS panels use a polarizer made out of a different material and requires a protective sheet unlike TN and PLS. Everyone who did AG removal on IPS panels got the graining issue, everyone that did AG removal on TN and PLS did NOT get the graining issue so It's not just limited to the specific monitors I did.
    cre3d likes this.
  21. natz
    natz n00b
    8
    Feb 21, 2015
    Anybody wants to tell if their screens have cracked after some time?
    Armenius likes this.
  22. MagnaMagicBtu
    96
    Jan 1, 2017
    I have gotten the "graining" issue ONLY with IPS panels, never with TN or PLS, even after cleaning them aggressively. The IPS panels started graining after just barely touching it. QNIX with the Samsung PLS panels do very well with removing the AG, It peels right off after only 3 hours of soaking and does NOT have the graining issue. PLS also has better colors than TN and is on par with IPS.
  23. natz
    natz n00b
    8
    Feb 21, 2015
    OP's monitor is IPs but he hasn't reported any graining... has he?
  24. MagnaMagicBtu
    96
    Jan 1, 2017
    He posted this on the first page "Screen is still fine, it developed a couple very small vertical grain lines in the middle of the screen that are completely invisible (and I really mean this, I've tried to look for them) while the screen is on. They do not have any kind of texture detectable when running a fingernail over them gently. I will take a few pictures with the screen on and post them in a little bit."
    I think the reason why his graining isn't so bad is because he didn't clean the glue residue off. I clean all the glue off because dust will stick to it and cause smearing/smudging issues. I wouldn't want a monitor that I can't clean. The reason why IPS panels grain and TN and PLS don't is unknown. The only thing I can think of is the polarizer is made out of a different material that requires a protective sheet while the PLS and TN don't. This is very unfortunate because a $1000 IPS panel will grain but a cheap $100 TN panel won't.
    If you want something to remove the AG on look for a QNIX with a PLS panel.
  25. Panmaster
    Panmaster Limp Gawd
    228
    May 31, 2013
    Finally tried removing the Benq bl3201pt bezel following this guide using plastic pry tools.
    Spent an hour carefully prying and not getting anywhere and causing mintor damage before reading this thread.
    I used as little force as possible struggling to get one edge to come off and then it cracked. Stupid.
    Time to get a new screen.
  26. MagnaMagicBtu
    96
    Jan 1, 2017
    Did you get grain lines when cleaning the glue residue off?
  27. Panmaster
    Panmaster Limp Gawd
    228
    May 31, 2013
    I never got that far. Removing the casing was just too difficult. I don't see how it's possible when it won't budge even with all my strength pulling it and hurting my hands yet the screen will crack if you so much as breathe on it heavily.
  28. MagnaMagicBtu
    96
    Jan 1, 2017
  29. Blubikins
    Blubikins Gawd
    910
    Nov 8, 2004
    Do you happen to have pictures of it with your computer and screen on? I have the same monitor and I'm considering doing this.
  30. MagnaMagicBtu
    96
    Jan 1, 2017
    Don't do it. IPS panels require a protective sheet or it will grain from just barely touching it. TN and PLS panels don't have this issue and the polarizer does NOT require a protective sheet. Read post #140.
    Blubikins likes this.
  31. eadgce
    eadgce n00b
    5
    Mar 4, 2017
    Currently at the 4 month mark and the monitor is working 100% with the polarizer being exposed to the elements. Will upload pics later tonight.
    EDIT: Yes, the vertical graining is present but barely noticeable, and only noticeable from very wide viewing angles and ONLY if you really try to fixate on the grain, Otherwise, the graining has in no way impacted my enjoyment form making the modification all these months later. This monitor became completely different once the coating was removed, like it all of a sudden became all "HD", and with it already being 4 years old and nearing the end of use for me, I figured what's to lose if I screw it up.
    So far, no regrets... it actually breathed new life into it and extended its purpose on my desk for (hopefully) several more years. I often think back to the night that I took the risk and soaked this $1000 panel from 2013, and I always smile when I turn on this monitor and see it the way it was meant to be seen.
  32. Trojita
    Trojita n00b
    23
    Jun 18, 2012
    So disappointing to hear this doesn't work on IPS panels :(
    I wanted to do this to my Dell U3415W.
    I developed a wavy pattern on my moniter that I was hoping I could get rid of when taking the AG coating off.
  33. acmilangr
    acmilangr n00b
    24
    Jun 21, 2017
    Hello
    I am glossy fan and i have a question please.
    What is the problem removing antiglare coating on ips panel? Does it make damage when you are clean it?
  34. Cylocybin
    Cylocybin Limp Gawd
    303
    Jun 3, 2018
    After you remove the ag is there no protection on the screen from the outside is that why people mention being extra careful when cleaning after the mod?
  35. acmilangr
    acmilangr n00b
    24
    Jun 21, 2017
    insoc123 likes this.
