Is there a definitive [H] recommended guide for cloning over a primary drive from a HDD to a SSD?
I think I am finally ready (long overdue) to make the jump from a traditional HDD to a SSD for my boot drive / primary application drive. I'd rather not have to reinstall everything from scratch with a new OS and whatnot if I can avoid it.
Currently in my rig I am on Win7 64 bit, using a 300 gb velociraptor primary/boot drive and a 1 tb storage drive.
I'd like to take the 300gb boot drive and clone it over to a Crucial M500 480gb (or similar SSD).
What is the start to finish process for this? What do I need to be aware of to make it all go smoothly / avoid doing to prevent messing everything or anything up? Will cloning my primary to the SSD cause any problem interactions with programs installed to the 1 tb storage drive? Is there a better place than this sub forum to consult on this?
EDIT: Considering that I am clearly somewhat lazy (as I am looking into cloning rather than starting fresh) should I just look into something like the Apricorn kit to do the heavy lifting for me? I am assuming that will take care of any alignment set up rather than having to do it manually, right? If I go that route do I still need to do the little things like enabling Trim after set up, or will it handle everything?
