My gtx670 is getting a little rusty for my lovely 32LD450 IPS 4:4:4 monitor. It is only 1080p60 and I hope it will last few more years. I know it will be a little overkill for 1080p60, but I change my GPUs every 3-4 years on my main rig, and I think extra oomph my help in a couple of years or if I upgrade my display to 1440p or 1080p144
At the moment I'm using Asus GTX670 which had no issues whatsoever. Last year I bought vanilla Zotac GTX970 for my kids HTCP in the living room, no issues there. However I did moded a little with Noctua's fans .
What GTX1070 would be best when it comes to noise levels? With my HAF922 case I should be able to fit any card there is.
I'm planning to buy it in the middle of September (saving some $$$ now and stock levels are very crappy), but since it is a lot of $$$ I would like to start my research early.
I like the Asus 3 fans solution, always wanted EVGA cards, and there is the MSI... way too many options...
Thanks in Advance.
Thanks in Advance.
