So I am perfecting my hopefully-soon-to-be ITX beast, and I was taking a look at new options for the gpu. So far, this is the build. As you can see, I have chosen the EVGA SC with the ACX 2.0 cooler (IIRC, it blows out from the two fans) and I was looking around to see what else I could choose. The MSI 4G and Gigabyte G1 showed up being praised as the best. They are also extremely quiet. On paper, the Gigabyte is the best of the lot with its core and boost clock. I cannot find any temperature comparisons of the brands, but hopefully you guys have any knowledge on that. I also cant find a video on the noise/sound of the EVGA version.
My priorities are obviously speed, the fastest card off the line, so please dont factor overclock ability into that. I might overclock it a bit once I feel comfortable doing so. My second biggest priority is noise, I want the quietest one. The EVGA has many complaints about coil whine and being pretty noisy, so that is not a good impression.
According to the video I linked about the sounds, the MSI is the most silent of the ones I have mentioned here, and the Gigabyte is almost as silent. I dont know if the silent MSI card is worth the small loss in clock speed (versus the faster Gigabyte card), but it also has the benefit of being smaller and $20 cheaper. The Gigabyte does have 3 DisplayPorts though, which would work out if I wanted to do a 3 monitor set up, right?
So, as far as speed goes... Gigabyte>MSI>EVGA
As far as noise/sound goes... MSI>Gigabyte>EVGA (not certain about the EVGA, no video on its sound)
As far as temperatures go... ???
Prices are all about the same, so that is not a factor right now.
One last thing, I know you might be thinking about them fitting in an ITX build. Well, I was worried the huge Gigabyte care would not fit in the Node 304 case, but this guy has it fit in well (a very snug fit, at that). His full build here. Since the Gigabyte is the longest of the three, I know the other two will fit.
Size... (small to large) EVGA>MSI>Gigabyte
So right now, the way I see it, considering all the factors and making my own judgement, choosing the best for me... Gigabyte>MSI>EVGA
I just keep wondering whether I should just get the near silent MSI card, and sacrifice a little of speed. Would the slight decrease in clock speed in the MSI, opposed to the slightly faster Gigabyte card, really make a difference?
Which would you get? Which should I choose after all?
Links:
EVGA
MSI
Gigabyte
Any help, feedback and recommendations greatly appreciated. Thanks!!
Links:
EVGA
MSI
Gigabyte
