I've seen that there are a few non-reference cards (at least in terms of cooling) being announce (and 1 is already released in the US) in the GTX 570 line. In a couple of reviews that I read (especially for older 470 / 480 cards) there was a big drop in temps and the bigger dual 80mm (or whatever) fans were slightly quieter even though they kept the card cooler. I would love to overclock the card, and I plan to keep it for about a year, maybe two, if that matters. I may SLI it when I get my SB upgrade.
I have a very well vented case, so the fact that these non-reference solutions don't vent directly to the outside of the case is not a problem.
What do people recommend? I think it would probably be cheaper and easier to buy a card that comes from the factory with an enhanced cooling solution, compared to buying a stock card + aftermarket VGA cooler. I've performed these cooling upgrades myself in the past, and while I don't have a problem with it, a) it's expensive and b) it's a hassle to investigate, order and perform the upgrade (I once had an aftermarket cooler sit on a shelf for 2 month until I had a weekend free to do the upgrade in peace).
Should I go with my instincts and get a non-reference card, or should I buy a stock card + VGA cooler and perform the upgrade myself? If the latter, what cooler is good for the 570?
What currently available card should I get (in the US), or should I wait for some upcoming non-reference card that looks good and is coming out soon?
