of what Kendrak listed, I would suggest looking at the Seasonic X650 the most. Followed by the EarthWatts
I had a TX750 once, very nice unit. That was the first revision, though.
Also, what are you using to monitor your temps and what are they at? There IS a thermal limit on most nvidia cards to downclock based on heat...
I use MSI afterburner for temp monitoring and overclocking. I've removed the stock HSF and replaced it with an Arctic Cooling Accellero Extremem PLUS II (which is overkill for a mid-length card). While OC'ed and folding, along with the OC'ed and folding CPU, the temps on the GPU hover around 70-75. CPU temps are around 50-55.
