GTX 1080 Overclocking Results Thread - Post yours here!
Discussion in 'nVidia Flavor' started by kring, May 31, 2016.
  1. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    Asus has already released their XOC bios, but that fixes the voltage in a basic way and designed for watercooling.
    Fingers crossed they release a more advanced one, one applied it to their Gigabyte Pascal and seemed to work for them but IMO that is not a good idea unless one knows the rating of the VRM used by the IHV or know that it is designed to be OC.
    ASUS GTX 1080 Strix OC / LN2 Prep / BIOS / Experiences - HWBOT forum
    BTW that is Dancop who was with der8auer when the AMD 480 hit 1700MHz.
    Cheers
  2. jedimasterben
    jedimasterben 2[H]4U
    2,343
    Oct 1, 2010
    The Asus XOC BIOS is a strange one. It has no power limit or any thermal throttling (even at the first few boost bin drops in the 50C range), but consistently gets lower bench scores and FPS in games at the same clock speeds as even the FE BIOS.
  3. Dayaks
    Dayaks [H]ardness Supreme
    5,327
    Feb 22, 2012
    Great work sir!!
  4. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    That is strange as I thought Dancop used the bios to hit constant 2.65GHz for benchmarking.
    Any link who was trying to use the Bios for gaming?
    Curious to see what was different, possibly using a FE card or another manufacturer with different VRM setup would be my 1st assumption *shrug*.
    Bear in mind for extreme most DIY OC probably still better to use EVM and hardware mods with the LN2 benchmarking.
    Thanks
    Edit:
    2.65GHz not 2.8.
  5. jedimasterben
    2,343
    Oct 1, 2010
    There are a couple of threads on OCN in the Nvidia section about it, a bunch of people verified the same thing I found with it, and it was across several different cards besides the FE.
  6. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
  7. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    Mind linking the OCN thread as would like to read it.
    Thanks
    Doing a search myself as well.
  8. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    OK I see a lot of various issues with other non-Asus cards used.
    Some FE that can tweak the voltage become unstable and that may be due to either the cooler not good enough or VRMs.
    Another with the MSI card cannot play with the voltage like Dancop could using same version of Afterburner.
    But as I said I would be very reluctant to use this on non-Asus custom cards.
    However as they have created one already, we should expect others; I think the Galax HoF one exists as well.
    Cheers
  9. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    Late to the party here myself in posting.
    The Sea Hawk still seems to have the same voltage behaviour as other BIOS/cards, excluding the Asus XOC and the Galax HoF custom one.
    Going by the reviews and their attempts to OC the 1080 Sea Hawk anyway
    Cheers
  10. jedimasterben
    2,343
    Oct 1, 2010
    It's possible that Asus locks the performance to Asus Strix cards. Go figure :)
    As for the FE cooler or power delivery not being enough, that is more than likely not the case, the cards are held back almost solely by power limit so long as you can withstand the thunderous roar of the cooler lol, at 100% the card stays around 60C in my case and only dropped two boost bins from temperature, the $60 for the EVGA hybrid CLC was well worth it to get some peace and quiet :)
    I'm looking forward to tweaking mine a bit more now that I hard modded the power limit of my card (from 126% peak power usage to 98%), now I have around 265ish watts to play with instead of 217w limit of the FE BIOS.
  11. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    I doubt it is locked but I think you are being funny :)
    But you accept something is strange when someone on a different 1080 manufacturer card (example was MSI) cannot set the V parameter in same way as Dancop when both are using the same Afterburner version.
    For FE it is not the power delivery but the increase voltage to the GPU, this puts further stress on the VRM and also greater heat.
    That increase is quite substantial (relative to normal draw) as you need to consider power loss within the VRM-power stage and GPU leakage when pushing it near the top of its performance scaling, so better cooling is needed for all these components.
    The problem is that these cards may use different PWM controllers and different VRM-power stages.
    This is further compounded with how Boost3 now works.
    Cheers
  12. KickAssCop
    KickAssCop [H]ardness Supreme
    6,386
    Mar 19, 2003
    Which brand to choose from. EVGA FTW, Gigabyte G1, ASUS Strix or Zotac Amp Extreme for an Sli config?
  13. revenant
    revenant [H]ardForum Junkie
    13,898
    Apr 10, 2005
    With the the G1, STRIX, and AMP cards, some are almost 2.5 or 3 pci-e slots wide, so take that into consideration... the eVGA and MSI will be the thinnest if your slot spacing is narrow. It seems any 1080 is roll of the dice pretty much. Some of the enclosed water cooled cards (MSI Sea hawk and eVGA hybrid) if you have room for the radiators might be nice due to getting that heat out of the case. Or the FE if you don't mind some fan noise..
    edit: with the Asus X99 Deluxe you should be good on slot spacing unless you have other cards (sound, ssd,) to mix in.
    KickAssCop likes this.
  14. Dayaks
    5,327
    Feb 22, 2012
    I can verify this is repeatable. Bumped 3dmark ultra about 500 pts at the same settings (5200 -> 5700.). I could break 6k if I cared, not into tweaking just for benchmarks right now.
    Thanks for posting!
  15. cageymaru
    cageymaru [H]ard|News
    16,684
    Apr 10, 2003
  16. NoxTek
    NoxTek The Geek Redneck
    9,023
    May 27, 2002
    OK, I keep hearing about this Asus XOC BIOS and that Asus themselves released it, but I can't find any official statement or even a forum post from Asus about this. Where and when did Asus release this BIOS? It sounds interesting....
  17. jedimasterben
    2,343
    Oct 1, 2010
    It will flash to any other 1080, but for some reason, even though it has no thermal, power, or voltage limits, it will allow higher clocks but performance is always lower on any card except for Strix and Strix OC. It's almost as if it lists higher clock speeds than it is actually running.
  18. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    Yeah I would keep it within Asus custom 1080 cards only, and even a well known OC says the same.
    1080strixXOC.rar beim Filehorst - filehorst.de
    As I say, it is a pretty crude approach but possibly done this way to overcome some Boost3 algorithm behaviour until they become more familiar with it, and also more designed for water block rather than air, so again shows this is more for the more extreme overclocker.
    Galax HoF also has their custom bios and found a reference once but cannot remember where, annoying even to me that I did not bookmark it :)
    Cheers
  19. QwaarJet
    QwaarJet Gawd
    584
    Mar 30, 2005
    On my FE 1080, I was getting 2070 but would quickly drop to just under 2000 once temps got into the upper 70's. I picked up the EVGA Hybrid cooler and now it's maintaining an OC of 2113 while being quiet and cool.
  20. eclypse
    eclypse 2[H]4U
    2,452
    Dec 7, 2003
    Does that clock sustain for a long gaming session? Or we talking 3dmark benches?
  21. QwaarJet
    QwaarJet Gawd
    584
    Mar 30, 2005
    Installation was a lot more involved than I expected, only go to run Heaven and play about 30 minutes of Doom (in 4k max settings)before having to get to work (from home) and the clock rate was sustained. Temps in the 40s.
  22. eclypse
    eclypse 2[H]4U
    2,452
    Dec 7, 2003
    Nice!
  23. bdbarb
    bdbarb n00bie
    1
    Sep 7, 2012
    ASUS Strix +220 core, +420 memory. 80c steady with 65% fan at 2050
    I picked up a Stock clocked ASUS Strix from Microcenter over the tax free weekend. While the online images of the box shows OC on them, in the store it wasn’t. Asus Tweak utility errors out on install, I had it previously installed and the fix to install it again is to reinstall Windows (yeah right!). EVGA PrevisionX to the rescue. I’m scoring about 16335 Firestrike (free) vs my 980ti 15226. Thinking it’s my 4.4ghz 2700k holding me back if those numbers are low? Odd thing with 3D Mark is sometimes it shows 850 core 933 memory, other runs 2050 core 933memory. Confusing.
  24. MavericK
    MavericK Zero Cool
    30,063
    Sep 2, 2004
    It seems like I am getting artifacts in the Valley benchmark with memory over 100+ and crashes with the Core over +75 or so. I didn't increase the voltage but I cranked the power target to max. Do I need to push the voltage as well?
    Temperatures are totally fine so I'm not sure why it's doing so badly with the OC. If I use the default OC profile which is apparently Boost: 1936 MHz / Base: 1784 MHz it seems fine.
    Gigabyte XTREME Gaming 1080.
    EDIT: I think maybe I'm reading the program wrong...those must be offsets from the OC boost because I can run Valley and I'm getting ~2.1 GHz on the core and ~10.2 GHz on the memory despite the "boost" clock being lower than that. I guess those numbers seem pretty respectable.
  25. morfinx
    morfinx [H]ard|Gawd
    1,110
    Feb 18, 2005
    Gigabyte G1 here.
    The best I could get is 2000 on core. 2050 core causes artifacts in both Valley and Fallout 4 (red or white "snow" that pops in and out). Lowering it down to 2025 removed all visible anomalies in Valley, but in FO4, while the artifacts are mostly gone, it still occasionally pops up. Only after lowering the core to 2000 do I not see any artifact in FO4. I tried it with or without memory OC, and got the same result. It's weird that it's the core OC that caused the artifacts, not memory OC.
    Final result: 2000 core / 5450 mem steady state while in game, 70C @ 66% fan. Ambient temperature is about 75F.
    I don't think I've seen any 1080 that had such a low OC. Did I get a dud? :(
  26. jedimasterben
    2,343
    Oct 1, 2010
    At what voltage? It took removing power limit for me to hold a steady 1.093v to get a stable 2100 when temperature is good. Before, voltage would bounce around and keep the same clock and would be unstable around 2000
  27. morfinx
    morfinx [H]ard|Gawd
    1,110
    Feb 18, 2005
    I maxed out the power and voltage sliders in Afterburner (108 power, +100% voltage). I later lowered the voltage limit to +75% once I settled on 2000.
    How did you remove the power limit?
  28. jedimasterben
    2,343
    Oct 1, 2010
    Voltage percents don't matter, what is the actual voltage? Is it stable? Post a screenshot of the afterburner log during gameplay if you can.
    Removing power limit requires a hard mod.
  29. morfinx
    morfinx [H]ard|Gawd
    1,110
    Feb 18, 2005
    I can't remember what the actual voltage was. I'll have to look when I get home. I don't think I want to do a hard mod though.
  30. jedimasterben
    2,343
    Oct 1, 2010
    Unfortunately a BIOS mod is taking significantly longer than with Maxwell (was less than two months) and I don't see any progress made on that front, so who knows when one will be available, so hard mods might be the only way to go.
  31. morfinx
    morfinx [H]ard|Gawd
    1,110
    Feb 18, 2005
    Just checked. It looks like the voltage is pegged at 1.081V under load.
  32. cybereality
    cybereality 2[H]4U
    2,656
    Mar 22, 2008
    I got a mild overclock on my MSI Gaming X cards.
    Power Limt: 115
    Core Clock: +110
    Mem Clock: +100
    Fan Speed: 90
    Getting sustained 2025 in game.
    Weird thing, I started overclocking while testing DOOM Vulkan, and it's a LOT more forgiving for aggressive clocks (+190 core, +500 memory). Then I tried Bioshock Infinite DX11 and had to dial it WAY down to get rid of these sparkly artifacts.
  33. 5150Joker
    5150Joker 2[H]4U
    2,458
    Aug 1, 2005
    AFAIK my buddy SVL7 was the first to unlock Kepler and Maxwell vbios mods that had no boost and power limit. After some people stole his work, he left the scene. Probably why it's taking so long for Pascal vbios to come out (if ever). If anyone cracks it anytime soon, it will be a guy named Prema.
  34. DF-1
    DF-1 2[H]4U
    2,110
    Jun 17, 2011
    I also have a G1 and its also a really shitty OCer. I thought +125 was stable (around 2050) but it seemed it was not, dropped to 100, seemed stable, 4 hours into a game again not, 75 same thing, even at +50mhz, i said fuck it and just left it at the default where it sits around 1900mhz.
    It seems the voltage drops really low when its in heavy use. temperatures are fine, and i did max out the voltage/power limits with the failed OCs. also, clocks are not smooth and stable with or without OC. it varies by 50mhz.
    :mad:
  35. morfinx
    morfinx [H]ard|Gawd
    1,110
    Feb 18, 2005
    Unfortunately, overclocking is always a gamble. Sometimes you win, some times you lose.
    Ieldra likes this.
  36. Ieldra
    Ieldra I Promise to RTFM
    3,521
    Mar 28, 2016
    if you're not against it, i suggest removing the cooler and taking a look, maybe the VRMs don't have good contact with the heatsink, maybe the paste isn't well applied.
    How are your temps ? Some chips can be particularly sensitive to temperature, does it behave any differently if you max out the fan ? At the end of the day it's very possible that you're unlucky and your chip tops out at ~1900mhz, it's still only around 5/6% lower than average.
    I can tell you that I can run 1500/8000 @ 1.221v all day long if the temps are below 65c. Above 65c there are increasing chances that it will crash, at 70c it's guaranteed to crash.
  37. DF-1
    DF-1 2[H]4U
    2,110
    Jun 17, 2011
    nah im not going to remove stuff.
    temps below 70. my previous card was an insane coil whine ACX3 (not SC,FTW, just basic) that could do like 2170 if i remember correctly.
  38. cybereality
    cybereality 2[H]4U
    2,656
    Mar 22, 2008
    Strangely, the overclock killed performance in Dying Light. On stock I was getting around 75-80 FPS, with the OC only 40-45 FPS.
    Even in the games it was working on, I was barely getting 2 - 3 FPS boost anyhow, so I'll just return back to stock for now.
  39. Maddness
    Maddness Gawd
    724
    Oct 24, 2014
    How did you increase the power limit to 130%. Is it a bios mod. I know both Afterburner and Precision top out at 120%
  40. misterbobby
    misterbobby 2[H]4U
    2,984
    Mar 18, 2014
    He clearly said "EVGA 1080 FTW" and those have 130% power limit. Also their base TDP is 215 watts to begin with instead of 180.
