around 2000-2100 depending on how loud i want the fan on this piece of shit coil whining ACX 3 thats going back.
Did you try putting it under a load that causes coil whine, perhaps Heaven or Valley benchmark, overnight to see if that clears out the coil whine? That method sometimes works, but not always.
I tried stressing it for 2 hours, it didn't seem to be getting better. I swapped out a cable on my ax1200i and plugged it into a different socket (its got a bunch, and its modular) and i think it made it worse. I'm really sad.
I've seen EVGA reps say to run it overnight which I interpret as 8 or 9 hours, so I'm not certain if 2 hours would do the trick.
I don't suppose you have a different PSU or computer to test it in? There have been instances where the PSU is the culprit - again, not often but sometimes.
So I left it overnight and its still noisy as hell. It's gotta go back.
I've ordered acx from newegg today. Hope it will be fine as I don't like messing with RMA, but at least it's EVGA.
Haha, for me thats a negative now. Issues with every single card that i got from them, GTX 580, 980ti and now 1080. I'm done with them, forever.
I can see why kyle doesn't like them.
I wish you the best!
Got my EVGA ACX at +215 / +500.
EVGA Founders Edition: +200/550Mhz, Afterburner 100% power, 120% voltage. Fan profile modified slightly.
This is inside a mITX NCASE M1. I have a Noctua fan at 900rpm feeding cold air into the GPU intake. GPU consistently stays above 2Ghz on long gaming sessions.
To be honest I am surprised its overclocking so well even with warm ambient temperatures and a small ITX case. I was expecting it to overclock poorly and was just happy to run it at stock speed. I also got lucky with the CPU which is running at 4.7Ghz (6700k). Currently the little rig is #124 in the Top 200 gaming rigs on 3DMark Firestrike I scored 19 573 in Fire Strike
I keep my fan at 60 and i don't hear it at all. You can start hearing it at around 75.How's the noise level on it? I got the same today and I'm on the fence.
Not bad, also makes me feel that my score of 17,984 (23,151 graphics, 13,438 physics, 8,303 combined) on a stock i7 6700k and a mildly OC'd GTX 1080 (+90/+400 and a custom fan profile) holds up pretty well. I, too, am running in a compact ITX case (Corsair Obsidian 250D). I like your idea of running a fan directly under the video card to help feed cooler air. I want to do something similar with my case since there is a bit of a gap between the card and the side panel vent. I don't think I have enough space for a fan, but I am thinking of maybe creating some kind of ducting that would force the video card to only pull air in from outside of the case. Once I get this done, then I may think on pushing the clock speeds a little more. I just don't want it to get too loud.
I have a Corsair H100i V2 cooling my CPU. I do plan to overclock it a bit, but the PC was only built at the end of April and I was making sure I had everything configured and stable first before tinkering with clock speed. I think I am going to keep the overclock mild, maybe 4.4-4.6 GHz tops. I need to do some reading up on the voltage settings first.
Well, I have a 4K display, so I do see some of my games not quite hitting 60 fps when maxed out (minus AA, resolution is high enough where I don't feel it is needed). So for me, the extra few frames may be of benefit to get closer to the 60fps target. Running anything below 4k has been cake walk.I feel like these overclocks are more for sport than to get real tangible results. The GPU+CPU combo is so fast that all games - including Witcher 3 - are running well over 60FPS maxed out. If you value lack noise and the warm feeling that things will always be stable, then just stay as you are. I'm a tinkerer at heart so I can't help pushing more and more, even though I probably can't notice the improved framerates
card I ordered on newegg was only eligible for exchange not refund. Although you could refuse delivery I guess.
I've managed to cancel for refund. I wanted to get asus or msi from the start, so I'd rather wait than regret. And I wanted to go with just 1070, so probably will save some as well.
MSI 1080 cards are a rip off. I'd go for the Asus Strix then although if it breaks you are screwed, their support is terrible (which is why I stick to Evga).
I've had very good luck with evga, even when I've had a problem with their product they took care of me. If I'm unhappy with my 1080 then I'll call evga or deal with newegg exchange for another one. Jayztwocents or whatever his name is reviewed the evga sc card I ordered and he seemed happy with it.
2 Evga F.E. 1080s core +265 , memory +700. I've found that there is no need to mess with power limit/temp just increase the fan speed and overclock watch your cards.
My EVGA SC 1080 is stable at 2.05Ghz core, 11.1Ghz memory.
MSI afterburner settings are +0% voltage, 120% power, 90C temp, +85 Mhz core, +550 Mhz memory.
Increasing voltage doesn't seem to do anything. Didn't play with the fan settings as it never gets over 75C with the stock curve and is very quiet.
Valley Benchmark DX11 Ultra Stereo3D disabled AA8x 1080p : Average FPS : 120.2
Score 5028
This score seems unusually high. You should be in the 110-116 FPS range. What do you get at 1440p? Did you let the card heat up for a while first?
Your Fire Strike scores look spot-on, though.
Your cpu will hold you back for sure in Valley not to mention some actual games. In many cases you would have seen zero difference by just getting a 1070. Heck you cant even stay above 45 fps in parts of Crysis 3 with your cpu where as a newer i7 would have you above 60 fps the whole time. You really need to upgrade to a 6700k and at least 3200 mhz memory if you want to get full use of your 1080 in all games.This score seems unusually high. You should be in the 110-116 FPS range. What do you get at 1440p? Did you let the card heat up for a while first?
