GTX 1080 FTW2 dual 8 pin.. can one 6 work?
Discussion in 'nVidia Flavor' started by Copyright, May 5, 2018.
  1. Copyright
    Copyright [H]ardness Supreme
    5,983
    Nov 17, 2000
    My last card had an 8 pin and 6 pin connection which I had custom cables made to match up. My new GTX 1080 FTW2 has dual 8 pin. is it safe to use one 8 and one 6 on this card? I thought the 1080 worked on a single 8 pin normally.
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    13,237
    Oct 7, 2000
    use what it requires
  3. VanGoghComplex
    VanGoghComplex [H]ard|Gawd
    1,713
    Apr 5, 2016
  4. Master_shake_
    Master_shake_ [H]ardForum Junkie
    8,917
    Apr 9, 2012
    It is fucking funny that you can literally splice a two pinned plug on from the existing wires but not just run a 6 pin.
  5. pendragon1
    13,237
    Oct 7, 2000
    yup but those two extra pins are there for a reason...
  6. gsilver
    gsilver Gawd
    583
    Oct 12, 2010
    The extra pins are mostly to guarantee that there's sufficient wattage.
    If there is, it'll work without issue. If not, it could put undue strain on the PSU and possibly not even work and/or crash.
