My Dell Precision T3500 needs a better graphics card than the Radeon HD 7790 in it. It is a card I had on hand so it went in, but won't play recent games well.
I originally limited my searches to cards less than 8.5" due to the hard drive door being a space confliction. I found out that since I can omit the top hard drive section ( un screws ) and I can install 2 2.5" drives in the lower bay ( will have 1 SSD/ 1 HDD ). I have about 12" to work with. I pretty much could use anything I want to up to a 500W/ single 6 or 8 pin connector ( I have 6 pin native )
Are AMD drivers still 'bad' in comparison to Nvidia? I know when I got the 7790 ( my first Radeon ) drivers were horrible but they at least worked for games I had
I'm more considering any RX480 in the $250 range, to the $250 PNY 6gb GTX1060. I know Zotac, XFX and MSI all make short versions around the same cost but I bet cooling or performance is better on the full size cards, otherwise there wouldn't be a need for a long card.. But which one do I get? I've read the reviews showing GTX 1060 a bit faster but I can't decide since they are SO close.
I won't loose anything by omitting the top hard drive bay. The box still has an unused 3.5" bay and unused 5.25" bay and I have 5.25-3.5" adapter brackets to use, so my storage solution won't change really
