GT4 - Arcade 2 Player Issue -
IndyGSX
For some reason if i use a car out of my garage I can't use any driving aides. TCS./AMS whatever.
Now if i pick any of the MFG cars out of the main area it will list that option. I have checked the options and it is set to allow the aides.
Sucks bad because i want to use my fixed up cars in my garage but without aides you know how hard it is to drive a 900+Hp car with that damn controller?
bullocks!
.:.Nate.:.
Scheizekopf
I have a little bit of a different question but it pertains to the Arcade 2 Player.
How do you do split screen horizontally (top/bottom) instead of vertically (side/side)?
Thanks.
Chickennog
According to the manual, the split screen format is determined by whether or not you have it in widescreen mode or not. If you're on widescreen it will automatically set itself to vertical and will not let you change it.
If you must have horizontal, change the screen setting to 4:3 for your splitscreen races.
