I got a GT 710 mostly just for giggles, it was $15. Specifically the MSI GT 710 2GD3 LP. It comes in handy as a tiny, portable gpu for testing motherboards, monitors, it needs only 25w, fits in any case, has all the display outputs you could need. It's a lot easier than moving my GTX1080 around.
First thing I noticed is its fan is a bit noisy, it is small so not surprising. I opened up Afterburner to make a custom fan curve and it appears the fan is locked at a minimum 50%! Why?!?! Theres a dotted yellow line at 50% that it just won't go below.
Is there any way to force a slower fan speed? It idles at room temperature, theres absolutely no reason for it to be screaming away at 50%. Anyone aware of custom BIOS for such a pathetic GPU? Is there any other way?
It does overclock like a champ! got it up to 1450mhz from the stock 954mhz, with 2400mhz effective on memory. Got something like 1100 on firestrike . And all the while, it's fan was at a constant 50% because 50% is already overkill!
