My monitor has gsync. If I buy a 3080 and play games at 1440p and the video card pushes more fps then my monitors refresh rate which is 144hertz, what do I need to do? Does gsync fix this? Do I need to enable vsync? I'll get tearing if my fps goes above 144 right? Should I cap my fps at 142? Keep vsync off? How should this work? What settings should I use?
Thanks!
I read i should enable vsync in the ncp and leave it off in game then set my framerate cap in ncp to 141. Vsync should be on in the ncp because you can still get tearing with gsync if its off. Vsync works in tandem with gsync to prevent tearing. Right?
Thanks!
