Great deal on Pre-N Wireless Adapter - $10
ALERT
THIS CARD DOES NOT HAVE VISTA SUPPORT!!!!1
http://www.belkin.com/support/vista/
This card is part # F5D8010.
The site says support is coming soon.
DO NOT attempt to install this with the 2000Pro/XP drivers from the disk on any version of Vista. It will crash your computer [H]ard-style. I'm amazed my RAID 0 setup is still functioning after that. Just a hard restart without any warning. Damn.
I have seen this work in XP though, the range is incredible and the PCMCIA adapter alone is worth the $10. The PCMCIA adapter does work in Vista and will install automatically, just not the wireless adapter itself.
Good luck to all who buy it. It is worth it if you are using XP.
