Yeah it is the hackintosh in the sig but at the moment only has the 3090 in it.. as I just rebuilt this pc and have to redo the wcing loop etc. nvidia control panel shows this. If I try changing any settings there are no other choices.. just 8 bit rgb full.is this you hackentosh in sig, what os? color bitrate maybe? are the gpu and monitor settings matched? ie, gpu is outputting 12bit to an 8bit monitor, maybe.
edit: this tool might help: CalibrationTools / calibration-tools — Bitbucket
check you monitor setting match rgb/bits. maybe try hdmi if you can. there are some posts on the google saying to look for a mac driver for the monitor.Yeah it is the hackintosh in the sig but at the moment only has the 3090 in it.. as I just rebuilt this pc and have to redo the wcing loop etc. nvidia control panel shows this. If I try changing any settings there are no other choices.. just 8 bit rgb full.
This is in windows though, don't have macos up and going on it atm. I had a 2080ti in this system prior (same cable/monitor) with no issues. I will try another cable though, I have some lying around here somewhere.check you monitor setting match rgb/bits. maybe try hdmi if you can. there are some posts on the google saying to look for a mac driver for the monitor.
oh ok. i was scratchin my head for hackintosh advice assuming you had macos on it. have you DDU'd yet?This is in windows though, don't have macos up and going on it atm. I had a 2080ti in this system prior (same cable/monitor) with no issues. I will try another cable though, I have some lying around here somewhere.![]()
I will give that a try now.oh ok. i was scratchin my head for hackintosh advice assuming you had macos on it. have you DDU'd yet?
probably mismatch settings somewhere. glad its fixed!Okay, it is fixed.. I did a factory reset on my monitor.. so strange but seems to have fixed it. Wonder if that is a sign something is going out on it.
