I plugged two 8pin connectors into my zotac 970 amp omega and after turning the pc on, I smelled burnt Plastic... I had previously had the 970 running fine with an 8 pin and a 6 to 8pin, but I wanted to support two full 8pin connections before I attempted to OC.
The card still powers up as far as I can tell in the configuration I used previously. All the leds and the fan turn on. Still, the card won't output video now. I took a picture of what I believe to be the affected connection that blew. Should I try to fix this myself (have access to am electronics lab at college) or is there any way this would be under warranty (card is 1 week old)?
Thank you!
https://www.dropbox.com/sc/xy95acgsq6l97el/AADxJljvUp6aOyIzrDh5zwq9a
Thank you!
