Hi everyone.
I'm starting to do research on good displays and would like input on 24+" displays for graphics and gaming on the side.
From searching and reading the forum stickies, the Dell 2407 seems like a good compromise for good-enough color reproduction and a great gaming display ( Dell 2407WFP - 24" WS Samsung S-PVA (LM201W01)). The 30" Dell seems to be just about identical to the Apple Cinema so I'd probably get an Apple Cinema over a Dell unless people here recommend against it on the 30" models.
The only other monitors I've considered are the Apple Cinema Displays. I have used an older iMac 17" LCD for over 3 years at work and it's color brightness, contrast, and reproduction are amazing.
I do less and less gaming of course, due to getting a life, getting married, starting to do gfx full time as my own business, etc... but I'd like a display that will serve well.
When I think about it, I start to convince myself that the Apple displays would be perfect because they will still be great in gaming, or at least enough for me to still do well in FPS and high-movement games whenever I do play.
What are your experiences with these monitors in gaming?
Currently I have a Mitsubishi 22" CRT (NEC has an identical display, using the same tube) at home that has been great for several years now. The reason I'd move to an LCD is for more layout space (even though I have a 2nd 21" CRT) and clearer colors for graphic design, and to have a larger display, period.
I'm probably not going to make a purchase in this area for 8-16 months and when I'm sure about what I want.
