GRAPHENE TIM: Build it and over clockers will come
Discussion in 'Overclocking & Cooling' started by SonDa5, Oct 8, 2012.
  1. SonDa5
    SonDa5 [H]ardness Supreme
    7,403
    Aug 20, 2008
    This would make the ultimate TIM in form of pad/grease/liquid application.
    honegod likes this.
  2. DeathPrincess
    DeathPrincess [H]ard as it Gets
    18,205
    May 15, 2010
    Yes graphene has high thermal conductivity, it's been known about since...graphene was discovered.
    But the problem is, getting the material into some usable application. You can't just stick a wafer of graphene between the heatsink, as thats not how TIM works (and would be pretty hard to work with). Youd have to mix it with something, and break it up (reducing the efficiency) to make it conform.
    Then you'd still have the main problem of any TIM. people not applying it properly. :D
    dvsman likes this.
  3. BrainEater
    BrainEater Gawd
    886
    Jul 21, 2004
    I'll reply again.
    Graphene is very cool....I think diamond is still better.
    Carbon materials are very directional.Yes they are fantastic materials for thermal management , but , correctly engineering it is very expensive.The lasers used in underwater fiberoptic repeaters are on diamond chips....for thousands of dollars a unit.
    It's really a waste to worry about 'super fantastic TIM'....I'd rather Intel make cpu's on diamond substrates.....
    :p
    hititnquitit and Armenius like this.
  4. SonDa5
    7,403
    Aug 20, 2008
    That is the challenge. A thin graphene pad would probably work well. It is flexible.
    [​IMG]
    I'm sure somebody is going to get rich with a patent on a TIM for graphene.
  5. BrainEater
    BrainEater Gawd
    886
    Jul 21, 2004
    I think you are right about that.
    We are entering "the Carbon Age"
    :D
    There's a video out showing nanotube manufacturing......very cool.......I'm sure a graphene machine would'nt be any harder.
  6. Forceman
    Forceman [H]ardForum Junkie
    9,243
    Aug 7, 2005
    It's flexible, but it still won't fill the microscopic holes that TIM is used to fill. You are just putting another solid between two already solid plates. I don't think that'll help very much.
    SvenBent likes this.
  7. DeathPrincess
    18,205
    May 15, 2010
    It's not so much flexibility as plasticity which is needed. Graphene is more like dry paper (flexible but not plastic), TIM is more like jelly (plastic and flexible and will conform to molds). Need to make Graphene paper mache somehow. :D
  8. bman212121
    bman212121 [H]ard|Gawd
    1,530
    Aug 18, 2011
    Nope, you just need Intel to make the top of the die accurate to the 1/10,000th of an inch without any holes in it. Then you can get a 1/10,000th of an inch cpu cooler which mates perfectly to the die without the need for TIM at all. :p
  9. spine
    spine 2[H]4U
    2,492
    Feb 4, 2003
    A Graphene IHS will probably be the first step in using it for cpu cooling.
    That's probably a decade away, realistically, factoring in the lack of mainstream demand for high performance (hot) chips that are increasingly being sidelined, business-wise, in favour of low power solutions for mobile devices.
    Maybe it'll appear in supercomputing in about 5 years. :cool:
  10. SonDa5
    7,403
    Aug 20, 2008
  11. Gorilla
    Gorilla [H]ardness Supreme
    5,919
    Sep 14, 2007
    Wow, $45 for 3ml. I'm sure it won't be long before someone gets some to do some tests with.
  12. SonDa5
    7,403
    Aug 20, 2008
    That is a little too high of price for me to just jump in without seeing how good this batch works.
    Theoretically the stuff should work great if it is mixed pure but I'm not sure how it will work doped with another material.
    Looking forward to some reviews.
  13. Cerulean
    Cerulean [H]ardForum Junkie
    9,218
    Jul 27, 2006
    Kyle should do a review over that TIM.
  14. SonDa5
    7,403
    Aug 20, 2008
    I'd like to see that.
    I really think Graphene is next big jump in TIM technology.
  15. Carbonblk46
    Carbonblk46 [H]Lite
    64
    Jan 31, 2013
    Sweet Jesus thats pricey! Look forward to seeing how it performs
  16. KazeoHin
    KazeoHin [H]ardness Supreme
    7,788
    Sep 7, 2011
    But hey, there are people out there who run 4 titans, $45 is practically pennies to them.
  17. -Dragon-
    -Dragon- 2[H]4U
    2,318
    Apr 6, 2007
    There are no more "big" jumps left in TIM. We're already to the point where delta T across the CPU to CPU cooler interface is in the 1/10ths of degrees using existing high end TIM, you really want to shell out $50 for an "improvement" that is less then instrument error?
    kirbyrj likes this.
  18. Cerulean
    9,218
    Jul 27, 2006
    They'd probably have to make CPU covers and heatsink bases out of nano-constructed surfaces for maximum perfection to make a difference... and perhaps utilize graphene in these rather than as TIM (actually, perhaps graphene to graphene to graphene would work well?).
  19. SonDa5
    7,403
    Aug 20, 2008
    Graphene still moving forward in electrical conductor design. Good stuff. Battery application is revolutionary.
    Cerulean likes this.
  20. BrainEater
    BrainEater Gawd
    886
    Jul 21, 2004
  21. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    6,012
    Jan 17, 2005
    I'll take it!!
  22. Josephrr
    Josephrr n00b
    12
    Feb 10, 2010
  23. Cerulean
    9,218
    Jul 27, 2006
    How well is the pad working over grease/paste?
  24. BlueLineSwinger
    BlueLineSwinger Gawd
    625
    Dec 1, 2011
    I'm betting it's worse.
    The purpose of a proper CPU TIM is not to form a layer between the CPU and the heatsink (as such a graphite sheet would). For the most efficient heat transfer as much metal-to-metal contact as possible between the two is best. The TIM is only there to fill in the minuscule gaps that exist when the two are joined together, as air is really a bad thermal conductor.
    Any time you see a thermal pad or such used it's because it's cheaper, for ease of installation, and/or heat transfer isn't as critical.
  25. Josephrr
    Josephrr n00b
    12
    Feb 10, 2010
    It works at least as good as MX4, I can run a half an hour of Prim95 SmallFFT's with a max of 70C, CPU idles at 35C. Not an exhaustive test I know.
    cageymaru, SonDa5 and Cerulean like this.
  26. SonDa5
    7,403
    Aug 20, 2008
    dvsman likes this.
  27. dragonstongue
    dragonstongue 2[H]4U
    3,055
    Nov 18, 2008
    graphene bonded with a water set bond agent ( like use on dentures LOL) or a combo effect of super glue and the thin a hair graphene layer or few?
    effectively allowing you to "peel" the graphene TIM pad (like those listerine pocket pack films) put on the cpu etc real careful and give a good firm press to "break" the small glassy seal on the "side down" use will make the solvent/bond agent seep through and make contact proper with heatsinks.. no delid etc needed... problem solved... should not be all that $$ either, probably .000001 per application ^.^
    They do post it notes, they do similar for glass protectors, I have seen like such for glass crack fixing, why not graphene etc peel and stick "pads" ^.^
    I call 1% profit world wide rights and will gladly be a tester and such as well.
  28. Kardonxt
    Kardonxt 2[H]4U
    2,856
    Apr 13, 2009
    dvsman likes this.
  29. DeeFrag
    DeeFrag [H]ardness Supreme
    5,452
    Jan 14, 2005
  30. Kardonxt
    Kardonxt 2[H]4U
    2,856
    Apr 13, 2009
    for TR it might be worth using the product in josephrr's, link cut down to size.
    I would be interested in a side by side of the two products, but now that I'm in an ITX build I don't mess with it unless I have to lol.
  31. mustang-SVT
    mustang-SVT n00b
    27
    Jun 1, 2019
    and intel throws a curveball with non soldered ihs.
