I also have a habit of leaving proximity mines in front of the mod shop....
Anyone else still having that issue where you need to alt-tab out and back in to get Vsync working properly? I always get very bad stuttering until I alt-tabbed once. There are many reports on the R* support page but the last couple updates didn't help. I play in Fullscreen mode, maybe I should try to force Vsync in the Nvidia Control Panel instead.
am i gonna have some slow downs if i install this on a regular 7200 rpm hard drive? if i install it on my ssd I'd have 30gb left over. assuming the install uses 60 gb. or does it get even bigger?
I generally find Nvidia's vsync to be superior to the in-game one. It works in every iteration (fullscreeen, windowed, borderless, after swapping windows, etc.) and it gives you a true 60hz, while the in-game version caps at 59 on many monitors thanks to rounding 59.94 down.
Thats not what hes talking about.
The game has a bug that locks the fps to 30 any time it goes under 60 with v-sync on. Forcing it in drivers doesn't help, the only way to fix it is to Alt-tab out of the game and back.
Mine goes under 60 all of the time with vsync on. Especially in the desert areas. I played for the first week using the in-game vsync and never got locked at 30fps. That must be a recent bug or it must not affect everyone.
Maybe.
Regardless, quite a few people here have it(go a few pages back), and Rockstar has a big thread on their forums about it.
Could also be the hardware, you are on a 980, I have a 670. Are you playing in 1080? I have to alt-tab every single time I play this game because of this.
Not sure what issues you are having, with having fun.
I seem to have a blast when i log in every night.
From doing heists or missions with friends/crew members or just running around in freeroam killing random people or calling muggers on them and watching them get pushed to the ground by the npc mugger.
There is really no shortage of things to do. i have 317 hours played so far.
i stay away from dumb game modes like deathmatch as i find that boring in every game not just GTA and never touch that mode.
So far my pegasus vehicle purchases include:
Tank
Insurgent 50cal.
Valkyrie
Hydra
Dump
Dodo
Merlin
Vestra
Marshal America
So i can cause some random havoc ranging from driving around in the monster truck to flying around in the harrier jet or driving around with some friends in the insurgent 50 cal. or flying with them in the Valkyrie.
i have even had some fun playing a game or 2 of golf with a couple people.
I think I've made like, 20k in a few hours of playing. Not nearly enough to buy anything interesting. Every time I try to join anything it's full or just sits loading.
Last night I got invited to play in a heist where we would of gotten 125k each or something. Right when the mission was about to end the host disconnected..You can run normal jobs solo, Escape, Online, Jobs, Rockstar created, Missions and then choose the one you are high enough level to start.
They range from 1-4 players to 1-6 and you can do them solo without a kuruma on hard.
You can also do Survival mode and if you beat all 10 waves you get 30k. the easiest maps are Processed (hide in the smaller of the 2 warehouses in the dumpster and just blind fire to kill everyone) and Sandy Survival there is a cornet section with a trash bin dumpster you can stand behind to clear it out. you can easily kill the choppers in the survival modes by shooting the tail rotor with the marksmen rifle that is way faster than going for pilots or gunners.
you can also join my crew since we play most nights as well if you need someone to play with http://socialclub.rockstargames.com/crew/o-wulf-o_o-pack-o
Can I join pls?You can run normal jobs solo, Escape, Online, Jobs, Rockstar created, Missions and then choose the one you are high enough level to start.
Yeah, I'm at 1080 in fullscreeen mode. Most settings pegged, but a few (grass, water) dialed down a hair. Sticking to FXAA instead of MSAA. There are times when I'm driving quickly in the desert (near the huge mountain) that I'll full-on drop down to 30fps, but it bounces back. I have Afterburner permanently on - I wonder if that's helping?
This sounds like you are experiencing the vsync bug. When you're in the mountain areas with lots of grass and you notice the game drop to 30fps, try Alt-tabbing out and back in and you'll notice your frames will no longer dip to 30.
I get the feeling it's actually a rendering issue related to vsync opposed to a frame buffering issue.
I don't think that's a bug, that's just the game being demanding with tons of grass and light/shadow effects on the screen. It isn't going right to 30fps - more like mid 30's for a few seconds. The rest of the game is 55-60 and it doesn't ever stay at a low fps, it just temporarily drops.
this game has the worst online system I have ever seen.
Getting in the same game as your friends is a terrible experience. It often fails, and when it does, it loads you back into single player, so you have to reload into MP, and then retry joining your friends game.
I just spent 2 hours going between loading screens trying to match up with a friend.
I get sessions where everyone drops, I get countless time outs. its just terrible.
honestly, fuck this, until they patch this, GTA is uninstalled from my system.
It is a bug when you can demonstrably see a frame rate increase simply by alt-tabbing out and back in. There is obviously a performance issue that is restricting the game from playing at optimal framerate.
When the game locks to 30fps and I use alt-tab, the game will often be restored to the 40's-50's range in the same offending area.
Multiple users have verified the same issue.
They really need to boost those rewards.finished my monthly objective today.
Assuming it takes 30 minutes per day, that's 14 hours. You can make $/RP four times faster by just doing missions.Wouldn't the total be $1.6m + 194K RP? That's not too bad.
