Hello all,
Would just like to have your opinions on a GPU to drive 4 screens in a 2x2 setup. This will be mainly for work, and no games.
For some reason, I hear or remember that AMD GPUs are better than this in this regard. As for the reason why, I do not remember...
Will an AMD RX 550 be enough for this purpose?
To add, it appears that most entry level GPUs nowadays have 3 display outs: DVI Dual Link, HDMI and Displayport. I don't want to have to buy a 'gaming' card for work!
However, most affordable monitors only support VGA, DVI and HDMI. What is the most effective option for this?
Edit2: Saw a Palit GTX1060 3GB with 5 outputs (3 Displayports, 1 HDMI and 1 DVI). I can get DP to HDMI/DVI converters but this is almost the same cost as just grabbing another lower power card...
Edit3: If I go the Kaby Lake + GT 1030 / RX 550 Route, is it a surefire thing that I can drive all 4 monitors with a combination 2 of outputs from the GPU (DVI+HDMI) and 2 outputs from the motherboard (DVI + HDMI)?
Thanks
Thanks
