On my 8600K rig I noticed something that maybe I dont understand what is happening here?
I have an Asus ITX z370 with 8600K.
I wanted to use the IGP to test out some performance in using transcoding compared to my GPU.
Then out of curiosity I fired up a round of PubG.
I noticed that my 1070 was spooling up the fan and making heat and I was getting over 100 FPS in the game.
I had absolutely NO LCD Connection to the 1070. Only thing hooked up was display port to the mobo IO which should be the IGP.
In the BIOS I even had IGP set as primary and multi monitor was turned off.
What gives? Is the graphics card now able to render and send the rendered game graphics over the PCIe bus to the IGP display port connector?
I am really confused as to why this is working?
on the flip side when I removed the GPU, still no display connected, never was, I noticed that PUBG was horrendous perfomance. Like Very Low graphics and was only getting like 15 fps. So with GPU installed and DP connector hooked to the IGP port I get performance graphics, but removed the GPU and I get awful performance.
I know PUBG wasn't using DX12 MultiGPU tech as the game is only DX11.
Thanks and I apologize as I am not a display aficionado .
