GPU no longer works with MB mystery
Discussion in 'Motherboards' started by M76, Jul 27, 2019.
  1. M76
    M76 [H]ardForum Junkie
    9,226
    Jun 12, 2012
    So here is the long version:
    I used to run a GT1030 Graphics card in my home server / HTPC. It worked without an issue.
    Then the machine developed some memory issues so I put it on ice until I could get some new RAM.
    Meanwhile I used an ancient E2180 as my home server for about a month. I put the 1030 into it, and it was fine.
    But now when I re-assembled the original system which has a Shuttle FX79 board, the system won't boot with the 1030. It stops after "Press Del to enter Setup" is displayed on the screen, and then freezes.
    The FX79 works with a different VGA, and the 1030 also works in other boards. So What the Hell? If it didn't work with this system before I'd say OK it's one of a million chance incompatibility but it worked before without an issue.
    ___________________________________________________________________________________________________
    The short version:
    Graphics card that used to work in MB no longer does
    Graphics card still works in other boards
    MB still works with other graphics card
    What do you think it is, and what do you suggest I do?
  2. mnewxcv
    mnewxcv [H]ardness Supreme
    6,444
    Mar 4, 2007
    Clear cmos?
    M76 likes this.
  3. M76
    9,226
    Jun 12, 2012
    Thanks for the suggestion, it didn't solve the issue, but it helped to narrow it down.
    So it seems the GT1030 fails to boot with the MB if the boot mode is set to UEFI. Why would a modern GPU not boot in UEFI mode is beyond me.
    The interesting thing is that the system is not frozen, it just stops and waits. It can be turned off by soft-off, and rebooted using CTRL-ALT-DEL
    Since my system is UEFI, I guess I have a 1030 for sale.
  4. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,359
    Sep 13, 2008
    weird that it won't boot into uefi since the card should support it unless there was some kind of bug in that bios. might be worth updating them or flashing the same bios to see if maybe the memory issues screwed something up. also is it stopping and waiting at windows or just waiting at the post screen?
  5. M76
    9,226
    Jun 12, 2012
    Waiting at the post screen before the memory test / storage init.
  6. Azrak
    Azrak Gawd
    820
    Oct 4, 2015
    Update the BIOS?
  7. M76
    9,226
    Jun 12, 2012
    I think the last bios update for this board is from 2013.
  8. M76
    9,226
    Jun 12, 2012
    LOL, I've contacted MSI's technical support regarding the no boot issue with uefi.
    It didn't turn out well. After half a dozen messages, the indian scammer in his second job/robot (I'm not even sure which is it but English was definitely not a requirement for the job) is still unable to get to grips with basic concepts.
    First suggestion from them: Try it without a VGA. Of course that is impossible since X79 has no integrated display adapter. But I assumed that was an honest mistake, nothing could've prepared me for what came after that.
