Hi,
I'm about to buy a new GPU. And I'm a bit confused about what to look for in my final card choice.
Which ever GPU model(970, 290, etc) you choose, there's multiple manufacturer and each manufacturer has multiple card available for the same GPU model. How to choose which one? The only big difference seems to be the clock speed. Simply get the highest or is it more complicated than that?
Also, is there "specific stuff" (cooling, component quality, reference card, etc) to look for? And which brand do you recommend (was thinking about getting an Asus or EVGA)?
Thanks!
Thanks!
