GPS/KML Editor
Discussion in 'General Software' started by raksasas, Jul 18, 2011.
  1. raksasas
    raksasas Limp Gawd
    477
    Dec 14, 2002
    Hi,
    I track my motorcycle riding routes with a program called: GPSed by GPSed.com. This app. run on my phone and does a good job keep track of me. Major benefit is being able to upload and share the route with friends easly. Now some times it has a hiccup and losses sign or sometimes in my case I forget to start it back up after a stop. So I am looking for a good GPX and/or KML editor. I have found some but they have a couple issues with them.
    Programs:
    GPX Editor (Use the most)
    Mobile Atlas Creator
    Must be able to:
    *add points within the track; not just at the end.
    * move points around within the track in point list
    *Identify a selected point on a track (some tracks have 10,000+ points)
    *Delete points.
    Thanks
  2. puzz
    puzz n00b
    1
    Sep 11, 2011
    Hi, I just made an online GPS track editor that has some of the features you need (move points, identify points, delete points) and some other (edit waypoints, remove parts of the track, split/join track segments, join tracks, find and remove GPS/elevation errors, ...).
    I'm looking for feedback from people who need a simple GPS editor. Would you be interested to try it?
  3. raksasas
    raksasas Limp Gawd
    477
    Dec 14, 2002
    Sounds good. I am willing to give it a shot. send the info in a PM
