I need a GPGPU workstation for work (raytracing/rendering) and while I'd usually build a machine myself my workplace requires a purchase order/etc... Best deal I've found is through avadirect.com which I like because it seems like it's basically a newegg shopping cart that will be assembled for me. Wondering if there are any recommendations on other vendors/system builders I should consider, getting quoted around $7.4k for the following system (can get it down to just under 5k by switching to 780ti's instead of Titan blacks):
WORKSTATION PC, Core i7 X79 4-way SLI® CrossFireX Six-Core Graphics Computer Workstation
FRACTAL DESIGN, Define XL R2
LEPA, Gold G1600-MA 1600W
GIGABYTE GA-X79-UP4
INTEL Core i7-4930K
NOCTUA, NH-D14
G SKILL, 32GB (4 x 8GB) Trident X DDR3 2400MHz CL10 (10-12-12-31) 1.65V SDRAM DIMM, Non-ECC
x4 EVGA, GeForce® GTX TITAN Black SuperClocked Signature
SAMSUNG, 500GB 840 EVO Series SSD
MICROSOFT, Windows 8.1 Pro 64-bit Edition, OEM w/ Media
WARRANTY, Silver Warranty Package (3 Year Limited Parts, Life-Time Labor Warranty)
Like I said, looking for advice on other vendors I should consider that may provide better support and/or price for something like the above system.
GIGABYTE GA-X79-UP4
INTEL Core i7-4930K
NOCTUA, NH-D14
