WD1000FYPS is also a GP drive. I use 8 until I ru out of space or 2TB ones don't break the bank!
It is older, and more or less same as 1000EACS but still here.
[LYL]Homer;1034759893 said:Keep in mind that the GP is 5400rpm and the LP is 5900rpm, a 9.25% increase in rotational speed.
The 1TB has been mathematically show to be 5400RPM and I can't imagine why the rest would be any different.
We have to take a different approach when assessing the Caviar GP's seek time since WD does not explicitly give users the drive's spindle speed. The GP turns in a measured access time of 15.0 ms, a score that lags the 7200-RPM WD7500AAKS by a significant margin. The WD7500AAKS's measured seek time when accounting for 4.2 ms of 7200 RPM latency is 9.5 ms (missing the firm's claim by over half a millisecond). Assuming the GP also shares such a seek time, that leaves us with 15 ms [measured access time] minus 9.5 ms [assumed seek time] which equals 5.5 ms, almost exactly the rotational latency associated with a 5400 RPM spindle speed.
I've always thought of IntelliPower as a wiz-bang-magic-keyword from the marketing dept. that deludes people into thinking these drives actually change speeds.
As always, YMMV.
WD10EARS 1tb 5.4 5.4 WD Green, 5400rpm, 64mb, 3yr
WD10EADS 1tb 5.4 2.8 WD Green, 5400rpm, 32mb, 3yr 1 2
http://www.pcper.com/comments.php?nid=8113Instead of each individual sector having its own Sync/header and ECC, the new format will move to larger physical sectors, in this case 4k. This results in an overall net gain in storage efficiency, so much so that Western Digital was able to save on wasted space even after shifting to a larger ECC block size. Larger ECC is a good thing, as Error Correcting Code is used to detect and correct bit errors that occur within each physical sector. The new ECC block size should translate to a 50% improvement in error correction ability.
EARS is newer and uses new Western Digital 'Advanced Format'
very interesting[LYL]Homer;1035144698 said:I had to redo my WHS box and followed the install with a Kill A Watt attached. I noticed that 1tb EACS drives connected into the mobo only showed a bump of 3w per drive, but moving a drive to the Supermicro AOC-SAT2-MV8 would bump the wattage up an additional 3w per drive. According to the specs in the OP my 8 drives beyond the OS drive (which is hooked into the mobo) should consume 30.5w (which correlates to my readings). This means that the SM card with 8 drives connected is using 20.5w at idle! The SM card with no drives attached was adding 5w at idle.
Here's the full specs of my system now:
http://www.hardforum.com/showpost.php?p=1035144663&postcount=86
Don't think you've got the WD20EARS-00MVWB0 yet.
More dense (677) platters than the original 2TB.
Thanks for your efforts though!
[LYL]Homer;1036317797 said:I do have the WD20EARS, and as far as I know WD does not distinguish in their specs for power, etc. between different platter configurations. I don't seem to be able to find a full review of the two models compared other than some superficial observations. If you do have a review link post it here and I'll add it as a footnote.
