Got the Corsair AX760....question on split 28 pin
gman
Ok, this thing has the standard 20/24 pin on one end and then a 18/10 on the other. I'm assuming the 24pin goes to the MB and 18 goes to the PSU. There isn't a place for the 10 pin that I can see. Any suggestions are more than welcome. Corsair instructions on this are non-existent.
mda
You are correct. The 20+4 pin goes in the board, and the 18+10 go in the PSU.
If you orient the PSU such that the 18pin is on top, the 10pin should be on the row beneath it.
18+10 connectors on the far left labelled "24 PIN ATX"
As a little added info, it's also like this for the Seasonic X and P series, which the AX series is based on (and which I have a few of). Hope this helps.
gman
Thanks man. Yep, it was a little different from most PSUs.
