w1retap
- Jul 17, 2006
When I plugged mine in, it shows up as a westinghouse w3 hdtv.. you can adjust all the resolutions the monitor supports right from the control panel display settings tab.
Imaulle said:2. is this correct DVI cable?? i ordered it before i knew there were different kinds of DVI cables
http://www.newegg.com/Product/Product.asp?Item=N82E16812119012
Imaulle said:two questions:
1. will my GFX card(in sig) support this?
jakescakes said:anyways, so how will I need to hook up the TV to my logitech z5500 and my pc?? Theres no optical or digital coax on the TV. Basically, I want to get digital sound (dts) from the cablebox and my pc using these speakers. I got the xplosion SC as well.
What games.. for most of them all you have to do is get the newest updates, edit the config file, or look for a 3rd party program that runs in the background to 'hack' the resolution size.kinson said:My only problem is... Getting a game to fit the resolution... That is the only pain... I'd love to have all my games running at 1920x1080 ... Would be so lovely...
r_customWidth 1920
r_customHeight 1080
r_customAspect 2
r_mode -1
CocoBee said:I was just wondering why the make the westinghouse models so cheap in price?
go into the game then set the res to 'custom' if it has it.. then hit apply and exit back out. Go into the right config file, edit the config file with your updated r_mode and custom height/width settings and save it. Then just go right into the game and start playing. It will still say 640x480 if you go back into the graphics settings in game, but when the game loads, it should be at 1920x1080. Thats how mine works with all the ones based off of the quake engine.Veritas616 said:Thanks for the help W1re, I've actually tried that, but it still defaults to 640x480, and every time I click back out of the game and look at the config file, the seta r_mode has changed back to 2 or 3, or whatever it was before instead of staying at -1. Any ideas? Thanks for your help by the way
use the shortcut command line hack. +szx 1920 +szy 1080 or something like that.. double check it.kinson said:well this is lame, I cant get my bf:2142 to run on this monitor, even at a lower resolution... I've tried all the supported, but none seem to want to work... Blah...
waitandsee said:Ran the 1080p test vids from Microsoft and my jaw dropped. 1080p is the future. Was about to buy the Benq 241W but I'm so glad I spent the extra $$ and bought this. This kicks the benq to the curb in my opinion! 1:1 Mapping is outstanding with the OPTION to have fill if you want it! REMOTE is very convenient to adjust backlight, fill modes, volume, and powering on/off!
Ladicius said:why not just buy a 42" monitor? it has the panels in the way, eww
jakescakes said:?????????????????????????
can someone tell me what video card i will need to game at medium to high settings at 1080p resolution?????
Im building a new rig for this monitor to game on. CSS, FEAR, guild wars, etc
so far i picked out
evga 7950gt KO
A64 4400x2 dual core.
will I be able to game on it at that high of a resolution with decent fps?? 50+
jakescakes said:where can I get a westy from?. newegg is sold out!!!!!!!!!
Ecca said:With the 37" at $1,100 and the 42" at $1,400 why not buy the 42" for the extra 300$? I am looking to buy one and I just want to know if there are problems with the 42 or why(if) the 37" is superior.[/I]
H-street said:what video card? what connection?
does the monitor just turn off or does 2142 just crash?
