gerardfraser
- Feb 23, 2009
So sold off my 3600X CPU'S and grabbed a cheap 3800X from buy and sell.Seems to work very good or normal,not sure about the 3800X yet,it's only been a few days with it.
So basically light load gaming up to 4650Mhz
Heavy gaming loads like BF5 can do up to 4475Mhz -4500Mhz all cores
I can say gaming is the same between 3600X vs 3800X no difference.
To anyone worried about the CPU voltage,it is OK.It is running off AMD settings and it has a 3 year warranty.I can also run it at lower voltage if I want to.
Video light gaming
HWinfo 64
Aida Memory Test
BF5
Computer used
Video light gaming
HWinfo 64
Aida Memory Test
BF5
Computer used
♦ CPU - AMD 3800X With MasterLiquid Lite ML240L RGB AIO
♦ GPU - Nvidia RTX 2080
♦ RAM - G.Skill Trident Z 16GB DDR4(F4-4000C18D-16GTZ) (2x8)
♦ Mobo - MSI X470 - Gaming Plus(E7B79AMS.AA0-AMD ComboPI1.0.0.3)
♦ SSD - M.2 2280 WD Blue 3D NAND 500GB
♦ DSP - LG 27" 4K UHD 5ms GTG IPS LED FreeSync Gaming Monitor (27UD59P-B.AUS) - Black
♦ PSU - Antec High Current Pro 1200W
