This is a list of programs that will keep you ad-free. Ive been running this combination for weeks and no ad-ware. Ive purposely gone to warez and porn sites which are infested with dirty ads and spyware that force their way into your computer.
List:
HijackThis
A general homepage hijackers detector and remover. Initially based on the article Hijacked!, but expanded with almost a dozen other checks against hijacker tricks. It is continually updated to detect and remove new hijacks. It does not target specific programs/URLs, just the methods used by hijackers to force you onto their sites. As a result, false positives are imminent and unless you are sure what you're doing, you should always consult with knowledgable folks (e.g. the forums) before deleting anything.
CWShredder
A small utility for removing CoolWebSearch (aka CoolWwwSearch, YouFindAll, White-Pages.ws and a dozen other names). Spybot S&D tends to forget essential parts of the hijack, so until it updates, you can just this to completely remove the hijack. Updated to remove the new variants once they come out.
Spybot Search & Destroy
If you have been here before, you will notice that we have completely redesigned our website. These changes should make it easier for you to find the information you are looking for, and at the same time easier for us to manage and add new content.
Ad-Aware
Ad-aware is an award winning, free multi adware removal utility, that scans your memory, registry and hard drives for known adware components and lets you remove them safely.
Proxomitron
For those who have not yet been introduced, meet the Proxomitron: a free, highly flexible, user-configurable, small but very powerful, local HTTP web-filtering proxy. To become better acquainted, please see our online copy of the Proxomitron Help Files for a more comprehensive overview.
Google Search Bar
Search the web with Google from any site
New! Eliminate pop-up ads *
New! Fill in forms with one click **
New! Link a weblog to the page you're visiting *
New! Restrict your search to pages located in a specific country *
Search just within the pages of a site
Highlight search terms on a page
Customize the layout of your toolbar
List:
HijackThis
CWShredder
Ad-Aware
Proxomitron
Google Search Bar
