Google Says It Is Discontinuing the Chromecast Audio
Discussion in 'HardForum Tech News' started by Megalith, Jan 12, 2019.
  1. Megalith
    Megalith 24-bit/48kHz Staff Member
    13,004
    Aug 20, 2006
    Google has announced that the Chromecast Audio will no longer be manufactured. The gadget debuted in 2015 as a cheap and simple means of sending audio from Chromecast-compatible apps to regular speakers via a 3.5mm audio cable. Support will continue for existing devices, however.
    …it’s probably a good time for Chromecast Audio to be discontinued, as the trend continues toward smart speakers being the default. Chromecast Audio as we know it could never keep up with today’s smart speakers, as it lacks Google Assistant capability. This could be a good opportunity for Google to launch a similarly affordable Google Home device that turns an older speaker system into a proper Assistant smart speaker, similar to the Echo Input.
    {NG}Fidel likes this.
  2. GlowingGhoul
    GlowingGhoul Whines about Whiners
    445
    Jun 13, 2013
  3. Shoganai
    Shoganai Limp Gawd
    504
    Dec 5, 2018
    Well that sucks. It was extremely useful. Maybe they'll incorporate it into the next Chromecast.
  4. Disco_Stu_04
    Disco_Stu_04 Limp Gawd
    426
    Aug 18, 2003
    These are great for receivers that do not have HDMI input.
    Armenius likes this.
  5. BloodyIron
    BloodyIron 2[H]4U
    3,439
    Jul 11, 2005
    So mad. I love these things and use them all the time! And I want like 10 more! Not sure if I'll even be able to get one come payday :/
    The next best alternative is a $400 option from Sonos.
    The Chromecast Audio devices are seriously awesome and Google cutting them has nothing to do with whether they sell or not, because they move like hotcakes!
    :( Sad
  6. daglesj
    daglesj [H]ardness Supreme
    5,150
    May 7, 2005
    I got one for about £15 a few years ago. I've never really used it but it works really well and it's hand to have a device with that functionality. I was hoping someone would make a neat little clip on battery pack that would give say 6 hours use but never saw anything. Would have been a nice to have.
    I might buy another one.
  7. harbingerofdoom
    harbingerofdoom Gawd
    772
    Apr 17, 2007
    i can see where some people might have a use for that.
    personally? id never wind up using it.
  8. ole-m
    ole-m Limp Gawd
    452
    Oct 5, 2015
    I've been looking at using one but seriously too expensive.
  9. Shoganai
    Shoganai Limp Gawd
    504
    Dec 5, 2018
    What’s too expensive?
  10. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    29,272
    Oct 29, 2000
    I didn't even know this existed. I would have bought one.
    I would never buy a smart speaker under any circumstance though.
    tangoseal and Armenius like this.
  11. lazz
    lazz Limp Gawd
    321
    Apr 15, 2007
    This is a real bummer. The Chromecast Audio supports really high bitrate streaming, and you can plug it into a stereo/amp via 3.5mm *or* digital optical. I've got the latter going into a DAC, then into my main stereo receiver - It has always sounded incredible for a streaming device.
    Really sad to hear this news, and probably going to go pick up a couple more just to have on-hand.
  12. Zarathustra[H]
    29,272
    Oct 29, 2000
    Bummer. I just tried to order one and it is out of stock in the Google store. :(
    I wish I had heard of these earlier.
  13. Zarathustra[H]
    29,272
    Oct 29, 2000
    If anyone is trying to buy them, they are still available new on eBay (but without the $20 discount the Google store had before they went out of stock)
    I ordered one.
    Kicking myself over that I never heard of this product before. Would have been very useful over the last couple of years.
  14. Bigbacon
    Bigbacon [H]ardForum Junkie
    16,152
    Jul 12, 2007
    never heard of it either....
    I wish you can could cast youtube audio to other devices but you can't.
  15. RPGWiZaRD
    RPGWiZaRD [H]ard|Gawd
    1,069
    Jan 24, 2009
    I've heard from people it has pretty bad audio quality for something specifically design to stream that so that might be a contributing factor too.
  16. Zarathustra[H]
    29,272
    Oct 29, 2000
    I'd suspect that it probably doesn't have the highest end DAC considering its price, but it does claim to stream in a lossless format, and it has an optical out, so if the device you are plugging it into has an optical in, you can bypass the DAC all together.
    This is what I plan on doing.
  17. Jagger100
    Jagger100 [H]ardness Supreme
    7,552
    Oct 31, 2004
    you can get HDMI to 3.5mm breakouts but nice ones will double the price of a chromecast.
  18. Sabrewulf...
    Sabrewulf... Gawd
    1,008
    Jan 18, 2008
  19. Disco_Stu_04
    426
    Aug 18, 2003
    Lots of options but I find it better in my setup to maintain a digital signal from a source all the way to the receiver. Chromecast audio has digital out and sounds great.
  20. Bootleg Usher
    Bootleg Usher Gawd
    701
    Apr 14, 2010
    I have an awesome Sony boombox with a 3.5mm stereo input. With the Chromecast Audio I can turn it into a wifi boombox which makes it even better.
  21. lazz
    lazz Limp Gawd
    321
    Apr 15, 2007
    Couldn't disagree more. I use mine with a toslink connection to a Schiit DAC but even before I had that it was just 3.5mm into my stereo amp and it sounded amazing. Much, much better than any bluetooth speaker/stereo.
    Here's a great review from What Hi-Fi that was published shortly after it launched:
    https://www.whathifi.com/google/chromecast-audio/review
  22. lazz
    lazz Limp Gawd
    321
    Apr 15, 2007
    m00ndancer likes this.
  23. ole-m
    ole-m Limp Gawd
    452
    Oct 5, 2015
    Same price as normal chromecast?
    35 bucks in my country.
  24. caddys83
    caddys83 2[H]4U
    3,355
    Feb 14, 2009
    So many people living under rocks! I have 4 of these things.
  25. UnrealRG
    UnrealRG n00b
    7
    Dec 28, 2018
    Really disappointed. I currently have a 10 speaker stereo (5L+5R) setup in my home office using these with a combination of receiver amp with traditional speakers and self-powered speakers. I setup the various Chromecast Audio (CCA) devices in a group so they all act as a single device. I love them and have plans to add them to my front porch and balcony, but need to rethink this now in case one dies and cannot be replaced. FWIW, the sound quality of CCA over my home network is so much better than Bluetooth, plus I can cast from my tablets, phones, and desktops. I also don't want any "smart" listening device in my home, but especially not in my office, so the CCA was perfect. I mostly use it with Plex for my FLAC music collection, but it can be used with pretty much any music service. Hope Google reconsiders, but I understand why they want to push "smart" devices.
  26. Zarathustra[H]
    29,272
    Oct 29, 2000
    I think it shows that Google kind of failed in publicizing these things.
    My Denon receivers (two of them in a row) have always had trouble connecting to Spotify Connect. Sometimes it works, sometimes it doesn't (and usually when I have guests over it seems to be the latter). Since my Denon receivers are the center of my multiroom setup (Zone 2 out to a distribution amp in the basement, and then analog runs to amps in a few different rooms) this is a huge bummer.
    I have on and off over the last couple of years been searching for some small streaming box like this I can use to add music input capability to the Denon receiver and not use its crappy built in Spotify Connect support, and in all my googling, I never came across the ChromeCast audio, and it lookes to be damned near perfect, with lossless audio formats, and the ability to use optical in on the receiver.
    Google really did not publicize this thing enough at all. I never heard of it, and even while searching never found it, until now, when the announcement of it being discontinued went out.
  27. choppedliver
    choppedliver Limp Gawd
    475
    Jan 3, 2005
    Idiots! I have 4. I've got them connected to old a/v receivers in 4 different areas of the house. I can walk from one to room to the other and they play seamless in unison. It was by far the cheapest way to do what I wanted, and I have ZERO INTEREST IN FUCKING A SMART SPEAKER.. I also don't want to listen to my music on your shit speaker in your smart speaker.
    I've already got nice speakers
    I've already got nice receivers (without all the network enabled stuff of current generation electronics )
    All I needed was a SIMPLE, CHEAP, way of getting them to all work together, and didn't want to spend wasted money on a) your crappy speaker b) your electronics necessary to make a smart receiver. Not everything has to be a swiss army knife! A simple tool for a simple use.
    It was a gadget with a specific purpose, and if they are going to get rid of them, I can only hope they fold it into chromecast, which I have several of, but have always been very annoyed that my receiver has a chromecast puck and chomecast audio puck plugged into it. The chromecast already does audio and video, why not just make it capable of synching with the audio cast? They are always sending updates, surely that could be one
  28. choppedliver
    475
    Jan 3, 2005
    On the other hand guys... they are cheap enough to buy "replacements" for future chrome cast devices dying or just needing some more for your setup
  29. ablazhov
    ablazhov n00b
    14
    Jan 5, 2007
  30. m00ndancer
    m00ndancer n00b
    11
    Apr 1, 2007
    It's good enough to be used as a headphone amp. For exact spec and measurements go here: http://archimago.blogspot.com/2016/02/measurements-google-chromecast-audio.html
    But fair enough, can't compare with a dedicated DAC for $200. I use mine (all four of them) all the time both as headphoneamp and a source for my older analogue equipment.
  31. m00ndancer
    m00ndancer n00b
    11
    Apr 1, 2007
    You can group CC and CCAs now. So I have a CC Ultra in the living room and a CCA in the kitchen and a CCA in the office at home. All of them belong to a speaker group.
  32. m00ndancer
    m00ndancer n00b
    11
    Apr 1, 2007
    Yeah that's a bummer, you can however run music.youtube.com in audiomode and cast youtube videos (only audio no image) to a CCA. Great for podcast and music videos of live performances
    It would be awesome if you could watch a YT video and cast the audio (in sync), but that might never be enabled.
    lazz likes this.
  33. Dr. Righteous
    Dr. Righteous 2[H]4U
    3,162
    Aug 1, 2007
    Yeah same here until found it was a feature on the Onkyo receiver I bought myself for Christmas. I assumed it was a wireless streaming feature. No wonder I never got it to work. Meh.
  34. Zarathustra[H]
    29,272
    Oct 29, 2000
    Just got mine. Hooked it up via optical cable to the back of my Denon AVR-x3300W. I set it up in the Denon as a CD player with optical input.
    Works like a charm. Sounds great. I wish I had discovered these years ago because I have been VERY frustrated with Denons built in Spotify Connect feature. It works sometimes, and sometimes it just refuses to connect. This just works.
    I was a little frustrated during the setup though. Google forced me to download the Google Home app and enable location services permissions for it in order to set up the device. It also refused to initialize with my home network connected via my VPN provider, so I had to create a special firewall rule for it to bypass my VPN. Jesus Christ, you can't do anything without being data mined these days. Really pisses me off.
    At least it works, and it looks like the Google Home app is only needed for the initial setup. Casting works without it afterwards.
    Current setup is as follows:
    Chromecast audio -> Denon Receiver (plays sound in Living Room)
    If I want multiroom, I enable "All Room Stereo" on the denon, and then it also plays on my speakers in the kitchen, on my speakers in my office and on the crappy Samsun soundbar in my bedroom, via my distribution amp in the basement.
    DYI multi-room setup. Got to love it.
  35. aokman
    aokman Gawd
    860
    Jan 3, 2012
    Chromecast? Oh you mean Crapcast
  36. Zarathustra[H]
    29,272
    Oct 29, 2000
    It works reliably, and with the optical output (bypassing the internal DAC in the thing) it sounds great on my setup.
    Just wish it didn't have to be tied to my Google account.
    lazz likes this.
  37. Zarathustra[H]
    29,272
    Oct 29, 2000
    My only concern is that now that it is discontinued, that app makers are going to drop support...
    Well, it was cheap. If it stops working, I'll be disappointed, but it won't have been the end of the world.
  38. Zarathustra[H]
    29,272
    Oct 29, 2000
    Alright...
    Does anyone know exactly how an android phone connects to a Chromecast device? Because we are having weird shit happen.
    So, "Living Room Speaker" is my new Chromecast audio.
    "My Dorm Speaker" on the other hand, is not mine. A check of all devices with DHCP leases on my network confirms that there is not some sort of rogue device on my network.
    This is my Fiance's phone. After failing to connect to my chromecast (Living Room), she tried the dorm speaker. And when she heard nothing, she cranked it up to 11 using the volume rocker.
    The only explanation I can think of here is that she was connected to our VPN via the PIA client (this explains why she could not connect to my chromecast) and some poor motherfucker who also uses PIA's Washington DC server (not sure why she chose that one, we live nowhere near DC) has a poorly setup OpenVPN configuration that allows remote connections in from the outside world, and thus their "Dorm Speaker" is discoverable and can play back music.
    So whoever you are in DC, if you got woken up by the Red Hot Chili Peppers turned up to 11 at 20 past midnight on a Thursday morning, you should probably check your firewall settings, because this shouldn't happen.
    That is all.
