Google Pixel and Pixel XL 2
Discussion in 'Smart Phones and Devices' started by Johnny78, Jul 26, 2017.
  1. Zorachus
    Zorachus [H]ardForum Junkie
    8,485
    Dec 17, 2006
    There's an update on the Play Store for the stock Google Phone app. And man they killed one thing I LOVED the most about it, the swipe to the different panels. I would always swipe left to my Favorites, or swipe right to the Contacts, or further swipe to the Voicemail. It was so smooth and fast, to just swipe from anywhere on the screen.
    Now it's been moved to the bottom of the screen, no more swiping, now you need to tap on which panel you want. Which to me takes even longer now, and is not as fast and smooth as before.
    I have been using the stock Google or ASOP Phone app for years, probably 8 years or so. This change is no bueno.
  2. ChronoReverse
    ChronoReverse Gawd
    990
    Feb 21, 2005
    Maybe send feedback about it? It really seems like a odd thing to take out.
  3. T4rd
    T4rd [H]ardForum Junkie
    15,977
    Apr 8, 2009
    Yeah, I hate this too. Looks like there's a lot of recent feedback/reviews about it in the Play Store too. Maybe send them an e-mail complaining about it as well, but I doubt it will do any good, it can't hurt though.
    Finally was able to pull the May security update on T-Mobile last night at least. Took a week for them to push the OTA :rolleyes:.
  4. ChronoReverse
    ChronoReverse Gawd
    990
    Feb 21, 2005
    Good idea, time to leave a 1 star review.
    Also, I'm glad I'm not on T-Mobile and have to deal with their weird slow updating ways. I heard that if you have a sim card from another carrier, you could force the update though (or just sideload, doesn't need root).
  5. Commander Shepard
    Commander Shepard Proud Brony
    3,087
    Apr 12, 2016
    I finally got my May update last night. Ten days after its release. I'm on T-Mobile, too.
  6. vegeta535
    vegeta535 2[H]4U
    2,297
    Jul 19, 2013
    Anyone notice the blue tint is a lot less noticable? Seem like there almost no color shift now.
  7. ChronoReverse
    ChronoReverse Gawd
    990
    Feb 21, 2005
    Mine is absolutely still there but it's not really an issue to me.
  8. exlink
    exlink 2[H]4U
    3,662
    Dec 16, 2006
    You most likely just got more used to it as time has gone on.
  9. T4rd
    15,977
    Apr 8, 2009
    I just got mine a couple months ago and it didn't really have it in the first place, at least it wasn't any worse than my 6P's display when I put them side by side (which is to say it's not really noticeable).
  10. Jaymzkerten
    Jaymzkerten Limp Gawd
    199
    Jul 30, 2012
    I'm a bit disappointed that 7 months in I already have burn in from the clock and notifications at the top of the screen. After the horrible burn in my GS7 had I now have it set to manual brightness and rarely take it above 50%. I feel like what they did to "dim" the soft buttons at the bottom should have also been done to the top as well. Definitely going to be flexing the warranty as I get closer to the 1 year mark.
  11. vegeta535
    vegeta535 2[H]4U
    2,297
    Jul 19, 2013
    0
    Had mine since November and have 0 burnin. I keep my brightness around 50%. Google will replace it under warranty if you have burn in.
    Commander Shepard likes this.
  12. Domingo
    Domingo [H]ardForum Junkie
    16,071
    Jul 30, 2004
    A guy I work with got an XL2 yesterday and it was minimal. Still there, but it was way less noticeable than my launch day version. His also didn't have the weird "gritty" look whenever there was too much white on the screen, too. I'd feel comfortable recommending an XL if they're all like that now.
    vegeta535 likes this.
  13. ChronoReverse
    ChronoReverse Gawd
    990
    Feb 21, 2005
    Yeah, mine doesn't have the gritty look at all. I would definitely be bothered by that far more than blueshift.
  14. auntjemima
    auntjemima Hand Jobs Legend
    4,234
    Mar 1, 2014
    I am running 100% brightness and now a few months in I have no burn-in. Screen has a 1 minute time out.
  15. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    53,969
    May 18, 1997
    Got my new one on warranty tradeout. Process was smooth as butter.
  16. T4rd
    15,977
    Apr 8, 2009
    I checked mine like a week ago and have 0 burn in as well, but I would hope a 2 month old phone wouldn't either and I got my phone after they implemented the inverted color nav bar stuff to negate burn-in. I usually only keep my screen at about half brightness (with adaptive brightness enabled) too.
    Interestingly enough, I put my phone up next to the S9+ I just got my mom this weekend and to me the displays are mostly comparable. The S9+ gets a bit brighter and doesn't ghost as bad at lower brightness, but otherwise I think the 2 XL holds its own against it now.
  17. Zorachus
    8,485
    Dec 17, 2006
    Android P beta 3 released today.
    I'm running bone-stock not rooted beta 2 right now, how do I do a clean fresh install of beta 3?
  18. RashMullah
    RashMullah n00bie
    38
    Oct 28, 2010
    They'll just send u the OTA. I'm running it, it's smooth.
    I also hate the change to the dialer where they removed the swiping btw.
  19. T4rd
    15,977
    Apr 8, 2009
    So anyone notice this delayed wake "bug" (2 XL only on the June update) that may have been an intentional change? Apparently the phone takes 2-3 seconds to wake up if you have the Always on Display disabled. My phone doesn't seem to be affected by it though. It might take a second longer to wake sometimes, but after testing it a bunch, it's rare or inconsistent at worst.
  20. ChronoReverse
    ChronoReverse Gawd
    990
    Feb 21, 2005
    Yup, introduced by the June patch and lots of people are upset about it.
    I'm using a custom kernel (Flash Kernel) that retains the fix that led to this bug while fixing the screen on delay.
    (the intended change adds 50ms of delay but we're obviously seeing more than that)
  21. RashMullah
    RashMullah n00bie
    38
    Oct 28, 2010
    I'm curious guys... Do you have your displays set to Boosted or Saturated profile?
  22. ChronoReverse
    ChronoReverse Gawd
    990
    Feb 21, 2005
    Boosted. Saturated is too much.
  23. Commander Shepard
    3,087
    Apr 12, 2016
    I'm still on the May update. I get updates around the 13th - 15th each month.
    Saturated. Brings the screen to life.
    Zorachus likes this.
  24. Zorachus
    8,485
    Dec 17, 2006
    Saturated, the other modes make it look to washed out and dull
  25. Nimisys
    Nimisys [H]ardForum Junkie
    16,330
    Jun 20, 2000
    Right now Verizon has 650$ toward a second 2/XL if you buy one at full price. worth while at this point? Wife has a 6P with a degrading battery and my MotoX has had a dead mainboard and i've been on a 929 for the last month. seriously considering this for us, but concerned about screen burn-in issues. Worth doing, or better considering something else or waiting?
  26. T4rd
    15,977
    Apr 8, 2009
    Definitely still worth getting IMO. If you've skimmed the thread over the past few months and saw any recent YouTube vids about it, it seems that they've tweaked the display a bit since launch. I got my 2 XL back in April and have absolutely no burn in right now and the blue shift was the same as my 6P had when comparing side by side (so not distractingly bad).
    FWIW too, these phones come with a two year warranty now and 3 years of OS and security updates.
  27. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,542
    Dec 23, 2001
    That averages about to be about 400 to 450 so it's not bad. One of the best overall packaged phone out there period. Jump on it
  28. T4rd
    15,977
    Apr 8, 2009
    Anyone notice WiFi disconnecting and reconnecting immediately thereafter? Mostly notice it in the Youtube app because it will say "back online" with the the green bar at the bottom every time WiFi reconnects. But I'll occasionally catch it switching to LTE and back to WiFi just while using the phone. It does it with any AP I've connected to (several) and while I'm close to the AP with strong signal as well.
    Not too big of a deal since it doesn't really interrupt anything, but it's a minor annoyance that shouldn't happen still. After seeing Kyle RMA his phone for WiFi issues, I'm wondering if mine is about to take a dump too or something.
  29. sgrinavi
    sgrinavi [H]ardness Supreme
    7,254
    Jan 18, 2009
    Anyone tried to replace the screen themselves on the 2xl ? Mines cracked and I just cant see spending $240 at the UbreakIrapeU store
  30. ChronoReverse
    ChronoReverse Gawd
    990
    Feb 21, 2005
    Maybe check developer settings and see if aggressive handover is enabled (turn it off). Might also want to turn off mobile data always on if it's turned on.
  31. Nimisys
    16,330
    Jun 20, 2000
    Ended up getting one,had to jump through some hoops, as they would only do the deal for new lines. Everytime I go through Verizon for a phone I fucking hate dealing with them. However wife had an unknown corperate discount so we basically got an additional line for the house for free. Which works as often one of the childcare providers will forget their own phone.
    Nice phone. OMG battery life.
  32. Commander Shepard
    3,087
    Apr 12, 2016
    Sonuvabitch!! My monthly security updates have been downloading automatically on the 15th or 16th of each month. I just checked manually for July's update and it's installing right now. (y)
  33. dcun201
    dcun201 n00bie
    25
    May 29, 2015
    Loved my pixel 2 xl. The standby time on this phone is crazy good vs my old oneplus 3.
  34. Nimisys
    16,330
    Jun 20, 2000
    Time to jump through more hoops, pretty much since day one my data signal has sucked, or at least been about Sprint quality. Poor WiFi reception, 3g and medium bars for cellular data. Thought it might have been newer Android being more accurate than my last Android phone, but same site at the same time comparisons with the wife's phone (same phone purchased at the same time from the same store) shows it's just my phone that sucks. But because it's been 3 weeks Verizon wants to warranty it with a refurbished unit and I have to go back to the same store that I bought it from.
    I am half tempted to give the phone back and switch to T-Mobile at this point.
  35. Zorachus
    8,485
    Dec 17, 2006
    Rocking DP4 now, and holy cow, just so nice. Smooth. Fast. No issues so far, absolutely daily driver ready. Zero bloatware, zero lag. It just works :)
    In my opinion, this is the best Android has to offer, I'll take a Pixel 2 XL running Android P DP4 over any new Galaxy S9+, or HTC U12, or LG G7.
    auntjemima likes this.
  36. SixFootDuo
    SixFootDuo [H]ardness Supreme
    4,985
    Oct 5, 2004
    I'm on my 2nd Google Pixel 2 XL, 1st one had to go in for warranty work ( blown speakers ) They sent me a brand new phone. But never saw a blue hue / tinge.
    Zorachus and auntjemima like this.
  37. auntjemima
    4,234
    Mar 1, 2014
    We are in slightly different boats. Overall, pleased, but there are a handful of issues.
    I have a Garmin watch connected via Bluetooth. I have to restart the phone every day or I won't have connectivity with the watch. When I remove the watch and try and add it again, it just hangs. Restart, no issues.
    Second issue... Let say I save 10 pictures to my device from the funny pictures thread here. It will give me a notification for every one. Then I try and swipe them away and there are always a few I cannot. Even if I click "remove all" at the bottom, they stay.
    Otherwise, no real issues.
  38. xorbe
    xorbe [H]ardness Supreme
    5,986
    Sep 26, 2008
    The June and July updates both had improvements for wifi connectivity with certain access points.
  39. Commander Shepard
    3,087
    Apr 12, 2016
    Since the July update my email program, Edison, constantly crashes. Had to go back to Gmail.
  40. T4rd
    15,977
    Apr 8, 2009
    My 2 XL is still having the same WiFi toggling issue that I mentioned above. Anyone else seeing that?
    I checked aggressive handover, as ChronoReverse suggested, but it was already turned off by default.
