staknhalo
- Jun 11, 2007
IBM’s Cloud Watson acted in a similar way for us. Set it up for some responses and it acted appropriately but then over night it “trained” itself and became unpredictable and essentially useless to rely on for even a simple demonstration. The Watson there doesn’t seem like the jeopardy Watson at all. It was far from impressive
It's specifically with voice recognition/problems with voice commands only - sometimes you will see (if you go into activity) it heard and understood exactly what you said perfectly - it's the correct command/words it heard - it just then for some reason didn't recognize and process the command
But if you go to text input/manual input for it via the Google Assistant app - it will understand just fine
Sucks because it's really the only part of my smart home that breaks, and breaks consistently, and it's so top layer you interact with it (or hope to) a lot
