You should be able to crank it without cracking a sweat. To give yourself some easy headroom: Put shadows at high instead of ultra and if you're going to use MSAA cap it at 4 otherwise you're better off using SMAA or Temporal SMAA.
Other than that: Crank it.
With my 290X I'm running at
2560X1080
All Ultra Settings
HBAO+High
2xMSAA
I have it on medium settings and Im still dropping to 40 FPS in some situations. Does it have anything to do with my 4GB of RAM? I'm planning on getting 8GB later today.
Well a 290X is signifigantly more powerful then a 290 right?
You can't use MSAA + Motion Blur at the same time.
I've locked mine to 30fps, soooooooo motion blur is a necessity.motion blur is one of those things i always turn off, makes games look horrible in motion.
Probably doesn't work.8X SSAA
Because of the marketing speak that has been flying around about consoles recently I think people are starting to believe that locking a game at a low framerate will prevent performance issues, or at least minimize stuttering in the case of Watch Dogs. A 66% dip in framerate is still a 66% dip, whether it be 20 FPS for the game running at 30 FPS or 80 FPS for a game running at 120 FPS.Why would you do that to yourself? Your on a PC not a console
???Why would you do that to yourself? Your on a PC not a console
My average frame rate while driving is around 40fps, my minimum somewhere in the low 30's.A 66% dip in framerate is still a 66% dip
I actually think it was my imagination lol, sorry guys.
What FPS are you guys getting at ultra settings with FXAA (ultra textures) with a R9 290? I want to compare, to make sure nothings wrong with my GPU.
Because 30fps is more cinematic? And W_D is a cinematic experience.
I really hope you are kidding
I figure locking to 30fps at least keeps things consistent. I'd rather have a constant 30fps than have to deal with bouncing between 30 and 50 over and over.
Why not lower some settings then? That low of FPS would give me a headache
Believe it.I seriously doubt a i7 will bump up my FPS 15...
Believe it.
http://www.tomshardware.com/reviews/watch-dogs-pc-performance,3833-8.html
I'm already looking to replace my i5 with a 4770k as close to at-cost as possible.
