Good rar program?
Discussion in 'General Software' started by Abyss of Borg, Sep 13, 2006.
  1. Abyss of Borg
    Abyss of Borg Gawd
    517
    Dec 29, 2005
    What's a decent free program to open .rar files? Most of them I can find look like they're either sharewhare or spyware.
  2. sdk
    sdk [H]ard|Gawd
    1,597
    Dec 2, 2003
  3. drdeutsch
    drdeutsch 2[H]4U
    3,780
    Sep 17, 2004
    Uhhh, how about WinRAR? I think you get a good trial version.
    Personally, I prefer 7-zip, which will unzip just about any format out there, and compress to .zip, .bkzip, and the great .7z format.
    drdeutsch
  4. Tweakin
    Tweakin [H]ard|Gawd
    1,280
    Apr 14, 2003
    7zip is the good 'free' answer to basically any compression, including RAR.
  5. Langford
    Langford [H]ard|Gawd
    1,339
    Apr 5, 2006
    7zip is great, and so is Iceows.
  6. Shadow2531
    Shadow2531 [H]ard|Gawd
    1,670
    Jun 13, 2003
  7. PTNL
    PTNL [H]ardness Supreme
    4,190
    Jan 2, 2005
    tugzip can handle zip, rar, and many other compression types ... and it's free
    http://www.tugzip.com
  8. t00thless
    t00thless Limp Gawd
    474
    Oct 6, 2004
    vote for izarc here!
  9. Duster
    Duster [H]ardness Supreme
    5,834
    May 4, 2002
  10. Eva_Unit_0
    Eva_Unit_0 [H]ard|Gawd
    1,991
    Jun 1, 2005
  11. CompuDrew
    CompuDrew [H]ardForum Junkie
    9,321
    Dec 31, 2001
    I like Winrar, but free sounds good. I think I'll look into those mentioned above for my other PC.
  12. Rix2357
    Rix2357 [H]ard|Gawd
    1,274
    Sep 15, 2001
    izarc
    It's good enough that I install it on all of my computers and I haven't bothered to find any better alternative if there is one. Winzip, winrar, and window's zip utility are either too clunky or the nag screen are all fixed with IZarc which is freeware.
  13. MrWizard6600
    MrWizard6600 [H]ardness Supreme
    5,777
    Jan 15, 2006
    yeah winrar gives you the function and nothing else. i quite like winrar.
    lol, but when you seach it in limewire half the results you get are "winrar.zip" :D
  14. MooCow
    MooCow [H]ardness Supreme
    7,360
    Apr 13, 2000
    I've used Powerarchiver, 7 zip and winrar. Win rar is the best one of the three, reason being, I've had some .rar files that 7zip kept on coming up with corrupted file errors upon extration. Powerarchiver also came across this same problem.
    I'd use winrar and it would extract just fine. So screw 7zip and the rest. Its all about Winrar.
